Sounds like the shut off pressure adjustment screw may have moved through vibration and needs re-calibration. Try manually opening the safety pressure release valve. If the release valve works as it should you have little to worry about.
Also, always remember to regularly drain the moisture in the tank to prevent rusting out the bottom of the tank.
