Air Compressor Questions ??
cire_50
New here and I'm sorry for asking these questions probably for the 100th time, but I was getting blurry eyed reading through old posts. I'm interested in getting an air compressor for my garage and I plan on eventually running just about everything ocassionally ... sanders, nippers, cutoff tools, sandblasters, etc. I've been looking at compressors in the $700.00 to $1000.00 range and my questions are:
a. Single Stage with better CFM or Two Stage with lower CFM??
b. Does anyone know of decent compressor for around $800 - $900 ...
60 - 80 gal. tank and no less then 15cfm??
Thanks in Advance !!
Eric
Major Ramifications
River Ridge, Louisiana
In answer to your first question, the two stage with less output is definitely better. It will give dryer air, will run more quietly, will put more air in the same size tank via higher pressure, and last longer.
C
cire_50
Ok ... anyone know anything about the following compressor ??
Craftsman Professional 80 Gal. Vertical Air Compressor, 5.4 hp.
This 80 gal. vertical air compressor from Craftsman Professional features a two-stage, oil-lubricated twin-V cast iron pump for long life and durability. Setting it apart, the pump contains automotive-style pistons, rings, connecting rods and sight glass. No magnetic starter required. Supports heavy-duty, continuous multi-tool usage.
5.4 running hp
175 PSI max pressure for longer tool run-time
89 dAB
240-volt only motor with manual thermal overload protection
SCFM Delivery At 100 psi: 13.3 SCFM
SCFM Delivery At 175 psi: 12.8 SCFM
Compressor Tank Capacity: 80 gal.
Maximum Compressor psi: 175 psi
Compressor Tank Pump Style: Twin-V
Compressor Tank Type: Vertical
Hose:
Function: Compressed air
Motor-Engine:
Horsepower: 5.4 hp
Type: Induction
Voltage: 240 volts
