air compressor selection
bocabil
I want to buy an air compressor primarily to fill the tires on my cars. I've read a lot of reviews and a common complaint is the excessive amount of time it takes to fill the tank; one review said it took 20 minutes to fill the tank and he got 2 minutes use before the refill restarted. Can someone recommend a compressor which fill its tank reasonably fast and is priced for someone who just wants to fill his car tires?
Thanks
Bocabil
jjjrmx5
Cincinnati, OH
If just filling tires and only tires I;d just buy one of the cigarette light plug-in compresor types found at any big box store. It's just a mini compressor and very very handy. Takes about 3 min a tire if almost flat.
I bought two many years ago at Meijers and I use them more often than having to drag the hose out and fire up the big boy compressor if it's not aired up.
If you want to buy a bigger real compressor, then also buy one of the "air pigs" as I call them or the mini tanks at HF or any retailer that is filled by your real compressor and acts as just a mini holding tank so you do not have to constantly use your main compressor. I can usually get two cars (8 tires) filled or maintained per pig fill up of air.
Everyone does their tire filling a little different but those $15 to $30 mini compressors that plug into your car's lighter is what I suggest.
They are pretty hearty, even HF sells a couple versions and you can carry it around or on trips in the even of a flat. Win-win.
If not then a small pancake compressor with a air chuck and extension cord should be just fine. I;ve BTDT too. You can find used pancakes on CL all day long for cheap. It's a roofer thang. lol
:thumbup:
Good luck.
RECox286
South Joisey (yeah, that is part of the USA)
^^^ I agree.
You don't need a machiine the size of a Caddilac to just ocassionally
top off the donuts. However, IF you catch the bug, and start to
want to have the tools and equipment that can be had with pneumatics,
then you will want to make the transition to "air pig" before you play
around with the smaller "toys". Best to make the choice now, rather
than be frustrated later.
Uncle Bob
niget2002
Josephine, TX
I agree also. I keep mine in the trunk and top off the tires while the wife is shopping in stores I don't care to go in.
Sent from my DROID RAZR using Tapatalk 2
