air compressor unloader adapter? (3/8 comp to 1/4 npt)
nychan
Trying to convert 3/8 male compression to 1/4NPT, anyone know of an adapter or idea on how to build adapter? TIA
Got a Puma PD1006 compressor for air lockers and tires in an offroad vehicle. When orig compressor switch stopped working, replaced with separate pressure switch and inline unloader. Unloaders (Control Devices-PA6) only seem to last a yr or 2 before they leak from the weep hole and comp continually runs . 1/4 NPT unloaders seem to be difficult to source while 1/4M NPT x 3/8M compression are available (amzn: Milton S-1097-6).
5ubtle
Spartanburg, SC
It seems odd that the PA-6 could leak out of the weep hole fast enough to keep the compressor running continually. :unsure:
The Cobbler
listed as a combo check valve & unloader .
where/how does the air unload? maybe a regular unloader/switch would last longer ? I seldom have unloader issues.
Has a Maximum recommended compressor speed of 400 RPM.
what is your RPM?
N
nychan
Your MMC link references copper tube, I'm trying to adapt at that point minus the olive and end up NPT.
Re: weep hole loss... Pulled it apart today. The PA-6 uses what look like internal tooth lock washers on both ends. Not sure I can get them off w/o damage beyond reassembly. Something is not sealing inside, maybe spring needs to be stretched? I did grab a Milton 1098-4 Load Genie (1/4" Female NPT 1/4" Male NPT) off ebay but like a backup plan.
This is what setup looks like except the factory puma check valve was replaced with street 90. That was done b/c the PA-6 is supposed to function as unloader and chk valve. Red arrow is PA-6.
TIA
N
nychan
what is your RPM?
air is escaping from weep hole on the side of the unloader prior to reaching air pressure switch > comp and comp continues to run eventually popping circuit breaker.
No idea on RPM, whatever it was set factory... where do you see max 400rpm?
TIA
