I've got an old Campbell Hausfeld 20 gallon compressor. It wasn't working when i got it and has had a handfull of repairs over the years.
When I replaced the pressure switch I ran PTFE tube to the unloader valve. That was fine for a while but now that I am running a blast cabinet it wont cut it. The compressor runs A LOT and the heat destroys the soft tube pretty quick.
So i am wondering what I should actually replace the PTFE with?
On the pump side it's 1/4" NPT, so my options are wide open for fittings. The Switch side uses a compression fitting that I am not so confident in..
I've got some brake line around and a flaring tool. Do I need copper line?
Any info appreciated.
switch for reference: https://www.amazon.com/dp/B00QHYERH0/?tag=atomicindus08-20
