onemeanls1
- Joined
- Apr 30, 2006
- Messages
- 4
has anyone had any experiance with the us general brand harbor frieght offers. they have a 60 gallon 5 hp it has 13.5 cfm @ 90psi. has anyone had band luck with these.
ImportTuner said:Hey Rayjay ... very nice setup ...
RAYJAY said:thank you
will try to get some better pictures
Jeff
bmwpower said:Is that an hour meter I see?
from granger redington model #3311-0000 mounted in a radioshack project box PoorOwner said:Hi Rayjay, looks really good.
What kind of wire is running inside those conduits? And that light is on when the motor is on, or just the Disconnect switch in general?
And how is the wire meter hooked up, should it be coming out of the pressure switch unit on the switched terminals? yours looks like tapped to the motor?
Alex Rayjay said:ad,Anti Vibration,Pk2
Neoprene Mounting Anti Vibration Pad, Size 4 x 4 x 3/8 Inches, Maximum Steady Load 50 PSI, Package 2
Grainger Item # 4C973
Price (pk.) $6.63
Brand MASON
Mfr. Model # 4C973A
Ship Qty. 1
Sell Qty. (Will-Call) 1
Ship Weight (lbs.) 0.4
Catalog Page No. 168
with red head concrete anchor's
PoorOwner said:Hi RayJay, I mean to ask if you ran Romex, the individual stranded wires or (THNN) inside?
Since it is 110V for the hour meter do you use neutral for the hour meter to complete the circuit or the ground? Techically, you are not supposed to use ground to complete circuits.
your not powering the meter with the 110 volts just turning it on.
