Air hammer as puller - my solution.
Olafur
Iceland
Reading this discussion couple of weeks ago triggered my memory. Few years ago I made a 'cradle' to use my Atlas Copco air hammer as puller. Here are some pics.
I made it for Atlas Copco RRH12, it's pictured here with RRH10 - one size down from the '12 and perhaps inch shorter.
In it's place. Just two flat bars welded to the end pieces. I made them from old hydraulic ram rods. The bolt on the left goes through a hole in the end piece, this one is 12mm and I use it to pull dowel pins from large transmissions. The pins have 12 mm threaded hole. The piece of bar stock is just a big 'washer' because the through hole in the bottom is too big for this bolt size.
I just use a short pin in the gun, the bottom is shaped like a bowl to keep it centered. And with a ridge , just in case.
Proably 16mm hole in the bottom, here it's easy to use threaded rods or whatever for pulling.
To be honest - when I made this - I was pretty amazed by the power of the Atlas hammer, and expected this to be a killer pulling device. Well, compared to a 10lb hand puller it isn't. But mind you a good hand puller is pretty effective device, meaning - almost all of the energy is transferred to the - 'job'. Still this is by no means a failure because it pulls a lot and is a great time saver on some jobs. Make no mistake, this is very different animal than hammering on some U-bent steel rods like this:
Zewnten
I like the idea. Do you think it absorbs a lot of the hit between the hammer and puller? Honestly I'd probably submit that to a tool company and see if they bite, if you care too.
Astro_Pneumatic_Tools
South El Monte
Love it. I prototyped one that slotted into the tool like a bit and worked similarly, But was deemed too hazard prone to work on multiple air hammer sizes and lengths and the danger of hand or finger squish there at the back
O
Olafur
Iceland
It does absorb quite a bit. One of the reason, and perhaps the main one is the mass of the 'cradle' absorbing some of the energy. Ideally it should be as light as possible. Another factor is stiffness, this one is pretty stiff, but probably weighs 4-5 lb. I haven't experimented with this design. Perhaps the flat bars I use are overkill and something lighter would give better results.
Another problem with this one is the end pieces are tad too small. If you look closely the flat bars are bent a little bit towards the ends. If I did this again I would make sure the flat bars or whatever I used would be perfectly straight. So this one isn't as stiff as it could be, the small bends in the bars cause this.
So basically I think there is some room for improvement.
Still, it pulls 18mm dowel pins, sunk (press fit) ~2" into corroded aluminum out with ease. I guess that requires few tons of force. It takes several blows with 10lb hand puller pull them out.
WoodsTruck
I like the idea.
I'm not quite sure I'm picturing how the energy is transferred from the hammer to the pulling frame.
In my mind, I would picture using a sacrificial chisel that has been cross drilled for a pivot pin in the end of the pulling frame. This would allow the chisel to pivot out of the frame, attach the hammer and then pivot back into the frame. If the parts were big enough it should handle the driving force and keep the hammer positioned a bit during use.
