Air Hammer For Pulling?
zendriver
Indiana
Ran across this vid of using specialty air hammer tools for pulling, verses using a slide hammer.,
Granted the demos in the vid don't look that stuck/tight, just wondering if those of you who use air hammers regularly think this setup might have some merit?
charbar
Midwest
The texas twister loses a lot of force through all the bends, you need a top of the line air hammer to start with, even then most often it's a fail.......................
I've always wondered that.... probably the reason I have never purchased one. I'm sure they have their place though.
BarrelRoll
Alaska
I've thought about buying one though haven't pulled the trigger yet. I pulled the trigger on a snapon air hammer a year ago and it's been a life saver for all kinds of things at work. My back and shoulders love it compared to swinging a hammer for hours. Just last night I used it to rattle some stuck bolts on a pump motor to work some PB blaster in. Then we went to fire up after a down day and a 6" knife gate valve on a tailings line was stuck closed. While I rattled the knife with an air hammer while a big boy put all he had into a 54" pry bar and we got it to move.
Vibrations do amazing things.
NYBODYMAN
NY
This actually looks like a very useful tool and a great idea. I can think of countless times I could have used this. Amazon has it for $234 which I think is a lot of money for a few pieces of metal but I can still see this making it's way into my tool box in the near future.
EDIT: I just watched this Wasted Money on Tools video. I can see how it might now work on all CV applications but to completely **** on it for just one of its uses not being effective isn't fair in my opinion. I think it still seems to have many uses besides CV work.
Wrench97
Southeastern Pa
Keep your money in your pocket buying a boat would be better spent...................................
rlitman
Long Island
Air hammers lose a lot of power with longer tools. I could see that working better with a thicker bar though. Maybe 1" diameter? It shouldn't be all that difficult a welding project.
zkdiesel
chicagoland cornfields
You lose the vibrations and force through the bends of the bit/adapter, the metal flexes.
It does
We own one as a shop tool
It does not perform miracles, but it is another tool in your aresonal to do some random strange things with. It does have a purpose but doesn’t live up to advertising hype
I’m spun many rusted/destroyed bolts out by spinning them with a top of the line air hammer.
nothing beats a slide hammer as long as you can grab it and have the room
Have several special slide hammers that I have made and welded my slide hammer thread nut on to make a tool
2ndGearRubber
Pittsburgh
Texas twister is garbage. I bought it right when it came out, it absolutely *****.
Steve_P
You should be able to look at that thing and see that it's nothing but a giant tuning fork
Z
zendriver
Indiana
Thinking that it doesn't put out some force, just seems foolish. It's hooked up to an air hammer.
How much and whether it's enough is why I asked. Mac tools sells it - So does Snap On.
If it does flex at the curve, it would probably benefit from a solid piece in it's place, IMO
Giant tuning fork? :wtf:
Olafur
Iceland
You may want to check out my solution to 'pulling with air hammer' I just posted here:
