Air Hammer Socket Adapters
Skin
Boston
I noticed these
http://buy1.snapon.com/catalog/item...&group_ID=2423&store=snapon-store&Part=PH1050
also noticed the price tag, and they're blue-point [rebadged?]. However i cant seem to find them anywhere else? Anyone know who makes them or of another brand to buy?
Ritter4.0
Maryland
I have no idea who else might make them, but I bought a Kobalt air hammer to play with and might make one of those for it.....
By play with I mean muffle, grind, drill holes in, try to make it a wannabe 3X gun :D
MXblur
I seen these last time I was on the MAC truck. Maybe check their website?
fatfillup
Finksburg, Md
I have one of those from an auction box lot. Has worked nicely on shocking rusted fasteners so they will come apart.
Skin
Boston
impact wrench would be a sideways force, these would be a downward force same as an impact driver and i'd think they'd be more helpful for freeing rusted/stuck threads.
metal1313
clinton NJ
but wouldnt that assume that the socket was supre shallow to allow the hammering to be transfered to it and not the surrounding material?
Skin
Boston
for a plain old bolt you'd have a point but most stuff used on equipment/vehicles has a shoulder to it so the socket sits on the whole bolt.
Americas finest city
You gotta use a shallow socket, or make sure there's a shoulder on the fastener, like above. And... set the air hammer to low or the bolt won't be the only thing that starts moving.
I've had better luck using this bit than using an impact driver. !Really!
scbird94
Sauk Rapids, MN
We use those and call the procedure "the shocker"
Works good on pt cruiser/neon rear subframe bolts that seize badly. Seen a ton break off or spin the welded nut inside body. hammer it a few times with that and turn by hand and it threads right out
LWaite
Denver
I have the 3/8 bit
Thing is amazing
First tool to help remove all the bed bolts on ford trucks
I got mine from the Matco dealer
