Air Hose Couplers
T.Hadley
Lake Tapps WA.
What type do you use?
I use the first style here, the second one seems to come with alot of things but I have found them all to leak.
Recognized by the extremely short pilot. Has the widest metal section between the ball groove and the pilot. The sealing surface on the end of the ****** is wider than other interchanges, resulting in better sealing and longer seal life. Intended for compressed air lines only. 300 PSI maximum rated working pressure
****** design is considered the industrial standard. Identified by the 3/16" pilot and flat bottom V-shaped ball groove. Intended for compressed air lines only. 300 PSI maximum rated pressure.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
I have never had leakage problems but the seals do wear out. I use the second unit.
There was a thread here a while back with all kinds of info on couplers.
ZRX61
Solar Blight Valley, SoCal
I use the first kind (T style) at home & the place I work uses the second type (M style). I have adaptors that work when using home tools at work.
I also use the V style (hy flow) on my spray guns & dedicated air hoses.
I also try to stick with Milton brand. Horrible Fright couplers are absolute ****.
crewchief888
NW indiana
all mine are the 2nd pic.
over the years ive bought tons of couplers, both male and female.
i seem to damage them before they ever wear out. ive been buying them from HD the last few years
rodnok1
NC
Which couplers can you drop from 8 feet and roll over and the still work, can't count how many I've ruined way before they can go bad. The HF one's are total ****, but I use them anyways...
Phuckin' Jim
North of the Peg
The one pictured in the second pic are type M, and are what I use. They are the cheapest, easiest to get, and the most common. Many of the female couplers have replaceable O-rings, buy 'em in quantity and replace as needed to fix leaks.
Also, couplers will last longer if you install "whip" hoses on your impact tools.:)
Phuckin' Jim
North of the Peg
You can get the steel version of any of the female couplers from an industrail supply store. They take way more abuse and cost about the same as the brass.:thumbup:
Keep them out of the water though, they rust easily!
Shadowdog500
Down the shore
I've been using the A style Milton 777 for years. They are easy to connect and release, and I cant ever recall having a problem with one.
I think people wind up using the connectors from the shop where they work. Seems like allot of people use the HF connector.
Chris
ZRX61
Related note:
I have a Goodyear hose that should say "Risk of BURSTING above *** psi" instead it says risk of BURNING....
It hasn't spontaneously combusted yet....
Ryland
Rhode Island
Related note:
I better check my goodyear hose. I wouldn't want my addition to burn down from it :)
Dan0myte
Regina, Saskatchewan
As far as I understand it:
Milton M-style are the cheapest and most common with consumer-grade tools. Highest chance of leaking.
Milton G-style are for flow-critical applications like sandblasters when the least restriction is required.
Milton L-style have the lowest chance of leaking and are used in most mechanics shops.
Milton A, T and P styles are meant for compatibility to old air compressor company standards from the 1960's and back. They're usually more leak resistant than cheap M-style couplers.
