Dr.JohnnyFever
- Joined
- Jun 15, 2008
- Messages
- 704
I could use some brainstorming help on bringing compressed air into my garage through drywall.
I have relocated my air compressor to a shed approximately 30' away from the garage. I will be burying PEX, in a conduit, to bring the air back to the garage. I am aware that the ground is cool, moisture condenses out, etc and already have a radiator style air cooler on the compressor. I have 3/4" PEX-A on hand and haven't decided on expansion vs crimp vs cinch/clamp yet.
The PEX will come up through 1-1/2" PVC conduit into an LB:
Something will exit through drywall inside the garage a few inches above the baseboard:
In the LB there will be an elbow. Either PEX-PEX, PEX-Sweat, or PEX-FNPT:
If PEX-PEX then PEX will exit the drywall.
If PEX-Sweat then 3/4" copper will exit the drywall.
If PEX-FNPT then a 3/4" ****** will exit the drywall.
So far, so good. However, now that something has exited the drywall, how to prevent that something from sliding in and out?
Mounting an 18" piece of strut on the drywall, from stud to stud is an option. As is a hardwood 1x4.
The air eventually needs to get to here:
Probably with copper tube either sweated or pressed, but I am really tempted to run PEX all the way and wrap it for UV protection.
Your thoughts?
Your thoughts?
