Air lines.. what are you using?
Lucid Moments
Gainesville, Ga
Rapidair
Just an FYI
The 3/4" Maxline kit goes on sale often at Northern Tools
Picked up a couple of their 3/4 kits for around $149 each
Comes with 150' hose and assorted fittings.
I bought a couple of the kits because
You get the fittings for less then if you buy them separately
I also ran a 100' line to a remote area because I had the extra tubing
I did the exact same thing except for the remote area bit.
The only gripe I have with the maxline is that it is a ***** to get it to run straight. At the end of the day mine looks crappy because I didn't choose to put the effort in to make it look good. But it works great which is all I care about.
niget2002
Josephine, TX
Anyone thought about running the rapid air tubing inside pvc pipe? The pvc pipe would help keep it more rigid looking.
Sent from my LM-G820 using Tapatalk
Firebrick43
West central Indiana
I don’t understand those claiming that their rapid air kits are “tons” cheaper than copper?
I am not going to compare the non ridgid 90500 kit as it’s only two drops and they claim it’s 1/2 but it’s ID is 3/8, it’s not ridgid, and uses push connectors that eventually will leak.
Their m3800 kit has three drops and the pipe has a 1/2” ID. That’s perfectly acceptable to me, it looks ok(but almost impossible to straighten to fastpipe or copper pipe straightness) and has decent compression fittings. It available in the 170-175 dollar range online.
1/2 M copper 20’ long at menards is 17.78. Multiply by 5 for 88.90.
Add $50 for some fittings and 3 ball valves and some mounting clamps and your at $140
If you want to use RapidAir that fine. Don’t try to delude others (or yourself) to thinking it’s cheaper or a better end product. It’s advantage is the “rapid” part.
EDS01SS
Not very happy with my rapid air kit. Im not sure if its because the pex tube sat in my hot shed for quite a few years before I used the rest of it or maybe I did something wrong. Mostly new fittings and almost all of them leak.I have tried going back and pushing the tube into the fitting more and sometimes it will stop the leak but it usually will start leaking again.Im probably going to scrap it and go with non rigid copper as mentioned above
mc1984ss
I used copper. A friend of mine had it in his business for many many years and even moved it to his new shop. Easy to work with and modify if needed. I even scuffed it with a scotchbrite pad and clear coated it to keep it looking nice.
zmotorsports
Northern Utah
Aircom system. Three sets actually to accommodate my 3k square foot shop and RV bay. Aircom is nearly identical to Rapidair with only a few differences in unions/couplers and manifolds. Personally I prefer the rigid aluminum tubing compared to the flexible that you have to straighten and comes on a roll but it's a bit more money.
bamawildcat
Some years ago I used Nibco chem aire lines and fittings to outfit my shop.
Well they stopped producing this stuff years ago and It does not hold up well. The pipes are splitting well under the max air pressure they recommended.
I`ve been soldiering on with the supply of extra fittings and pipe but the time to rip it all out and re do it is near.
Soo what are you using?
Cast iron, pvc and prolly copper are out so what else is working?
RapidAir makes fittings to go to ChemAir. Scroll all the way down:
https://www.rapidairproducts.com/accessories
May help you replace the problem areas as you go and save money until longer runs are needed.
59 wagon man
hollywood fla
copper twenty yrs here and i reused what i had in my rented warehouse before i built my home based shop. so its about 25 yrs old and still looks new
bob15
Northeasten, CT
I use 1" black pipe.....Canadian-made pipe and US made fittings and valves. If I didn't have a Ridgid 500 pipe threader, I might have gone with copper.
klassenl
Southern Alberta
PEX straight from my locally owned Home Hardware. I had the good fortune of being able to run it during construction so none of it shows.
jubilee
Colorado
My home system is 30+ years old with never a problem or hint of a leak. Somebody gave me a few hundred feet of 3/4” black pipe to make some gates. I used some of it for airline. Line is all welded and bent with pipe bender. There is one union in the system. Union is the only fitting and it’s welded in, not threaded.
I have two collars welded in to accept drain valves and of course there’s threads at the compressor end.
I was lucky to have the equipment to fab an airline that is far going to outlast me.
sfanale
California
Plain ole’ PEX from Home Depot with ****** fittings and crimp rings. Works perfectly, totally safe, readily available.
If you’re super concerned with straight neat lines, that can be challenging with PEX—so that could push you to rapid air or hard pipe. But if you’re careful, you can get a decent look with PEX and it does the job.
brownsmustang
SWMO
We just signed a contract on a new home with a much larger shop. I ran the maxline 3/4" system on my current shop and built my own straightener and love the system, but hate the expense of adding drops as the fittings can be pricey.
But I'm leaning heavily towards copper on my new shop. I think I may run 2, 20'x2" lines as the first lines from the compressor, that should give me a bit of extra capacity, give the air some time to slow down and cool down. Not to mention I'll run my blast cabinets directly off it. Then neck it down to 3/4" copper for the rest of the drops.
derek_m
So what type of copper pipe ie wall thickness etc?
Type K hard copper tube would be best, its thicker than Type L or M.
My garage has copper tube, been in there for ~27 years. Ball valves for drains, quick disconnects in 3 locations. Compressor is connected with a quick disconnect and rubber hose.
A friend put rapidair in his garage, no issues. Another has steel pipe and threaded fittings, no issues either.
LS6 Tommy
Northern NJ
Guys, M is rated for more pressure than any "normal" compressor system is ever going to see. Annealed (soft) 1/2" is rated for over 400 Psi working pressure, 825 Psi burst and 3/4" is rated for over 300 working, 650 burst. Drawn tubing is even stronger.
Save the money.
Tommy
matt_i
Save the money.
Tommy
Agree, the thicker copper is for acidic water which can eat the thinnest wall.
Or, more exotic apps like a refrigerant delivery system that thru one of my old plants at around 300psi.
quadrcr87
Travelers Rest, SC
Look at the pex air line kits. A ton cheaper than copper or black pipe. Iwas looking at a 100' kit for under$175. It gets very good reviews. I'm switching over to it. I've got pvc and it scares people. I haven't been too worried, it's rated 460psi and still is pliant. But, I have a son in the safety industry who will keep poking till I do it.
Sent from my SM-G973U using Tapatalk
I saw a trick the other day where people cut out the unions but leave the PVC lines mounted to the wall. Then just run the Rapidair lines through the PVC and use their connectors at each opening. Its fast and neat.
Andrew
fourjeepin
Atlanta, GA
I looked at 3/4 inch Rapidair.
I ended up just using PEX line. Cheap and quick and has worked great.
Me too. I’ve known for years my pvc lines needed to go and started looking. The 1/2 rapid air was too small an ID and I decided against the 3/4 due to the cost. After a good bit of searching, I found reports from a few others that used regular pex. I had the roll of pex sitting in my shop for probably a year before the pvc broke at a joint and pushed me to install the pex. It was FAR easier to install than the pvc and should last much longer too. Not to mention being safer and having fewer fittings.
rhythim
Tennessee
3/4" Maxline here. Currently just 3 drops, one built into the workbench, 1 to a reel, and one to the blast cabinet. I have enough materials left for another couple drops, but what's there now has been sufficient thus far.0683c7e19e5463af770bac54d19c58b5.jpg3d8200cd6cec12f5eaf907ceea54f4b9.jpg
Sent from my SM-G988U using Tapatalk
ericm
Southern Oregon
I did that. The original builder of my house put in PVC air lines in the garage. I'd have kept using them but the siding and window replacement damaged them and required cutting some of the lines. I cut more out and ran rapidair in the remainder.
1/2" rapidair does not flow as well as 3/4 PVC. It's noticeable even with an air impact wrench. When I get my shop built it'll have a larger compressor and more air using equipment, a 3/4" main line with 1/2" drops, in copper.
Jeffh40
SW Ohio
Just a garage and not a business. Copper is my go to. I have Pex water lines in the house and, although they do the job fine, they just look sloppy. I don't mind soldering.
rayra
Escaped from Los Angeles
It's funny to see the bias against PVC. Especially with its very low cost and ease of installation. Use sched40 or higher, don't put it where direct sunlight can hit it. A simple painting would also prevent that UV risk
Look at that burst pressure rating for commonly available 3/4" sched40. It's 10X the rating of your air tools, your compressor emergency relief valve.
https://www.pvcfittingsonline.com/resource-center/strength-of-pvc-pipe-with-strength-chart/
And who needs to leave their home garage / shop air system pressurized 24/7/365? Or rather, who can't wait or do something else for the couple minutes it takes your compressor to come up to pressure?
Bigblockyeti
Upstate, SC
What does that chart look like after a few years of compressor blow by allowing direct contact with oil which may or may not contain certain hydrocarbons, ketones, or cyclic ethers?
