What kind of air saw blade would be best for cutting 7 inch diameter holes in sheet metal?
B Bellaireroad Well-known member Joined Mar 22, 2013 Messages 636 Location Fort Worth Sep 6, 2016 #1 What kind of air saw blade would be best for cutting 7 inch diameter holes in sheet metal?
D dnschmidt Well-known member Joined Oct 3, 2014 Messages 7,318 Location Phoenix, AZ Sep 6, 2016 #2 A plasma cutter used with a circle guide.
P pepi Well-known member Joined Mar 27, 2013 Messages 2,883 Location Woodstock, GA Sep 6, 2016 #3 Sheet metal ........ in a word, nibbler. Very manageable and easy to use. Plasma cutter the new buzz word, not real practical for sheet metal. Unless we are talking CNC mass production. Attachments 1.jpg 74.6 KB · Views: 23 2.jpg 67.1 KB · Views: 23
OP B Bellaireroad Well-known member Joined Mar 22, 2013 Messages 636 Location Fort Worth Sep 6, 2016 #4 I don't have a plasma cutter or a Nibbler. What kind of blade would be best to use to cut circles 7 inch diameter in 18 to 20 gauge sheet-metal? Sent from my iPhone using Tapatalk
D dnschmidt Well-known member Joined Oct 3, 2014 Messages 7,318 Location Phoenix, AZ Sep 6, 2016 #5 The standard ones that come on air saws. You don't want the ones that look like a cut down hacksaw blade as they are too thick to cut the radius you're looking for.
S slow_mow Well-known member Joined May 6, 2016 Messages 58 Location Middletown, CA Sep 6, 2016 #6 I've done quite a bit of sheet metal work with my air saw. I've had the best luck using Bosch Jigsaw Blades: https://www.amazon.com/Bosch-T118G-3-Inch-36TPI-Jigsaw/dp/B000UMLQ9W/ref=sr_1_1?s=hi&ie=UTF8&qid=1473186876&sr=1-1&keywords=bosch+metal+cutting+jigsaw+blade
OP B Bellaireroad Well-known member Joined Mar 22, 2013 Messages 636 Location Fort Worth Sep 6, 2016 #7 thanks
M machine_punk Well-known member Joined May 14, 2011 Messages 2,540 Location Napa Valley, California Sep 6, 2016 #8 +1 on Bosch blades. I'd likely do that with a jig saw, though. KDub.
