BrianJ said:
That's just it. I don't know what the "standard" is.
In order for me to order the couplings & plugs, I need to know the thread size, thread type, body size.....
Thread size is going to vary with what tools or accessories you are installing the male ******* on.
Most air hoses have Male 1/4 pipe thread on the ends. You would need a Female 1/4 pipe thread ****** for one end, and a coupling on the other end also with Female 1/4 pipe thread.
Virtually all air tools have 1/4 pipe Female threads on the inlet, thus you would need 1/4 Male pipe thread ******* for these tools.
Your compressor or wall fittings will vary. Most likely they will be 1/4 female or possibly 1/4 Male pipe thread, and you will need couplings with the appropriate matching pipe thread.
Ocassionally, you will encounter an air tool or accessory with Female 1/8 pipe thread , and there are male ******* with 1/8 male pipe thread to fit these.
Ocassionally you will encounter air tools or accessories with Male 1/4 pipe thread inlets, and you will need the 1/4 female pipe thread ******* llike you would use on the end of the air hose.
There are three common air ******/coupling styles. The most common is the "industrial interchange" type. Used by just about everyone.
The second most common is the "automotive" style.
The third type, is what I refer to as the short lincoln, also known as the Aro 210 interchange. It is very similar to the Industrial fitting, but has a slightly longer ****** and a different shaped groove for the ball locks.
Here is a chart showing the various *******. Different brands of couplings look different, but if they are made to take a certain ******, it doesn't matter which you have, it will accept the ****** if made for it. Some couplers have large exposed sliding collars to operate the ball locks or the bar locks inside, they are easy to grab but also are easy to accidently disconnect while dragging it across the floor or if you bump it. Some have much harder to grab sleeves to unlock them, but less likely to unlock when you don't want them to. Some couplers require that you pull the sleeve back, push the ****** in and release the sleeve to lock it. Others merely require that you push in the ******, the sleeve will slide to the locked position automatically and you are done.
http://www.centralstateshose.com/amfloidchart.php?PHPSESSID=2fe06a1f79cc856316c46f46e9ee7034
Use couplings or ******* with whatever pipe thread that you need to connect to whatever you are screwing it onto.
Here you go, and even better view of the ******* and couplings.
http://strickequipment.com/catalog/aircouplers&plugnipples.htm
The truflate catalog in PDF, lots of good pics.
http://www.plews.com/downloads/download_common.cfm?file=Tru-Flate_2003_Catalog.pdf&folder=brochure
Charles
