Alternative to foam closure strips?
tlmartin84
West Virginia
Are there any alternatives to these? After a few years, it seems like several "walk out" and then expose whatever is underneath to weather.
1776089727606.pngHas
jack stand
Lakes Region Maine
Usually there's something to screw to where you'd have an under or over closure.
Screw through it.👍
Have a hammer tacker handy for under closures to keep it in place before you drop the panel on it. I only put one down at a time so the "timing" doesn't get away from me, it's easy to stretch it out and chances are you will putting down 3 or more ahead of the metal.
T
tlmartin84
West Virginia
Screw through it.👍
That works for inner panels, outer panels think ridge caps, roof to porch transitions etc are more of a problem. Even with a screw the cap, foam and into the rib and board underneath, they walk out.
jack stand
Lakes Region Maine
Any ridge cap I've ever seen has a hemmed edge at the fastening location at the very lowest (down slope) edge(s). This is where I put'em.👍
Screw through them on every 9" major rib attaching your ridge cap.
There's a roll out breather made to match roofing profile. It's the same type of "scrubbing pad" material that is commonly used under an asphalt shingled ridge.
I also usually have to add another purlin to match the particular caps fastening location. I'm just not smart enough to figure this out ahead of time. 😆
jack stand
Lakes Region Maine
I'm not good at speed reading!
That's what I did to your last response. Excuse me please.
I've had some tails, (closure strips) beyond the last screw behave like you describe. Screwing at every major rib is about all you can do short of the venting roll type of closure.
There's probably an adhesive that you could use during installation but I don't have any suggestions for after.
T
tlmartin84
West Virginia
Usually I just shove them back in with some silicone on them, I may look into the rolled stuff. I live on a REALLY windy mountain, and if those aren't in it blows water up the roof, and into the ridge. (It's a 6/12 pitch roof)
