Aluminium container insulation
jabberwoki
puyallup wa usa
So i have an uninsulated 20 ft aluminium container that i want to spray something on the insides to help with condensation.
I was thinking undercoating but i`d need it to be a light color or paintable so it's not to dark also cheap as it's a big area.
Whatdoyareckon?
NOEYEZ
Spray on Bed liners can be acquired in many colors.....Can you tell us what you will use it for? This might help us to zero in on what you truly need...
J
jabberwoki
puyallup wa usa
Car storage so it needs to be dry.
, so trying to stop condensation from forming on the walls and ceiling
Bondo
Greenfield, Maine
Whatdoyareckon?
Ayuh,.... An inch of spray-on closed cell insulation will do exactly what yer lookin' for,.....
BillK
Beautiful Southern Maryland
If you are not worried about the temperature I would bet that a small roof vent and a fan to keep air moving would be much better at keeping the condensation down.
65ranchero
Danville, VT left NJ forever
They have kits that are DYI but it get expensive because i think a kit does not cover much area.
Plus I suggest a respirator.
A local insulation Co. can knock that off fast.
There is this:
dshop
get a local pro to shoot the spray foam One and done...this is a specialized application that requires proper equipment and the expertise to apply it successfully. Your health will be safe, your building will be safe and all is good.
If you want to spend more money and risk your health, DYI.
