ALUMINUM: how to cut thick stuff...
unclemoak
Wisconsin
I'll be cutting 1'' square tubing that is 1/16 inch thick. My cheap $39 chop saw does it in about twenty seconds. It makes a damn mess everywhere, smells (toxic chemicals from the disc blade) and makes more noise than my ar-15). So getting a saw that can cut this first, and foremost, is very important.
I may very well have to buy a horizontal saw and verticle one, I suppose.
The plating I'll be cuting is either 1/8 or 1/16 thick and only two inches wide, sort of like a strips of steel cut into small pieces. The strips look like a belt you would wear to hold your pants up. My chop saw gets too hot cutting it, and as mentioned above.
Sounds like a horizontal would be just about perfect for what you intend to do with it.
pop pop
Virginia
You will not likely believe this, but the best cut will be with a chain saw for heavy thick aluminum. There is a special blade for this and they wear fairly quickly. I worked for one of the largest aluminum companies for 30 years. Extrusions and billet would be cut with very large round blade saws @ 200+ HP and 4' dia blade. But when we were building plants with buss made from cast aluminum (8" thick X 3' high) we used chain saws. For those little bitty items you are cutting [ ;-)] go with the band saws, preferable horizontal. You are likely to get hurt with a hand held skill type saw. They will bind and kick awful. Slow it down and use lots of coolant and ask for the special tooth blade for aluminum. A good supplier will know which one. And good luck. Aluminum isn't just "aluminum" as there are many alloys and they will work differently. 7*** series will be difficult.
Bootybug
Can't beat one of these for $280: http://www.amazon.com/gp/offer-list...ower-hand-tools&ie=UTF8&qid=1293217878&sr=1-2
I would also look for "CPO (insert brand name)" and buy refurbished.
Lot cheaper and faster than a bandsaw or 2.
Edit: Loud? Heck yeah. Wear earplugs. Lots better than a hand guided bandsaw cut, both in speed and quality. Set up a stop, pull the trigger, repeat.
It keeps me where I am today, though; loud, messy and fumes. I do like the saw a lot. But it really just becomes a chop saw, doesn't it.
That's some crazy sht. Crazy by one man's standard is a workable solution to another! If I'm ever stuck in an elevator with nothing but a pen and a knife, I want you with me.
danski0224
Near Naperville, IL
There are no fumes. Put on a non-ferrous carbide tipped blade, and it will cut like a hot knife through butter. No different than wood.
Loud? Yes
Messy? Unless you buy a dedicated metal cold cut saw with chip collection... yes. Hook a vacuum up to the dust port and get most of it.
But, based on the descriptions of what you are cutting, even if it is 100's of pieces, a metal cutting saw can't be beat. It will be faster and more accurate than any bandsaw in a similar price range. You are only going to be able to buy Harbor Freight stuff for under $1k. Used USA machinery will need work at that price point.
It is NOT the same as an abrasive cut off saw.
Edit:
I used one of these on a job for 6 months: http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=309
Couldn't tell you how many cuts were made in Unistrut and threaded rod. Same blade that the tool came with. The saw was used daily.
Bootybug
Even the thick aluminum? And how is this any different than my current miter saw?
metal1313
clinton NJ
the metal cutting saws are alot more powerful than a regular miter saw, and spin much slower..i want one but the need has not arised that i have to have one..yet
danski0224
Near Naperville, IL
That Makita is probably not much different from a fixed wood cutting miter saw, except for chip collection and the vise. Maybe motor RPM, too.
A sliding compound miter saw would give more versatility. If you need to make 90* cuts on stock that fits within the capacity of a non-slider, then that will be a less expensive route.
Yes, it will cut thick aluminum just fine with the proper blade. The blade will dictate the rate of cut- don't force it.
Some abrasive chop saws spin at a faster RPM than a wood miter saw. Watch the blade operating range when you buy one.
Zeke
Another note: AL blades for circular saws should have a negative hook (or rake) angle.
Bootybug
Yeah, in reading there is a significant difference between miter saw machines and multi-purpose cut saws (look very similar, though).
It appears the most significant drawback of these saws is the blade cost. That said, lubrication can help extend that. It is small so that is a huge plus. It is loud though so I'll have to deall with that, I suppose.
Here's one...
http://www.amazon.com/gp/product/B0000302QS/?tag=atomicindus08-20
Bootybug
On steroids...
Wonder how thick of aluminum this could cut?
JET J-F225 1-Horsepower 115-Volt 225mm Single Phase Manual Bench Cold Saw
gmwelder86
Oakdale , ca
most cold saws will cut what ever you put into them. We have used a porta cable cold chop saw to cut 4x4x3/4 square tubing at work for pipe supports just take you time and get a good carbide blade.
some zilch
not sure why the total disregard for the HF 4x6 bandsaw? mine has cut thousands of pieces of alum/steel/cast etc, and is probably the best $200 i ever spent. its quiet, shuts itself off when its done, and does not throw **** all over the shop. i havent touched my chop saw since getting my hf bandsaw
7echo
coastal Georgia
One thing that will help with the little Jet/Grizzly/HF, etc horizontal saws is doing the research and getting quality blades. A good blade and coolant pump will help make the job much better.
Bootybug
I've read where they require a lot of adjusting to get them to work properly. Having one, do you believe it can cut 2.5 inch solid aluminum?
Bootybug
Everything is on the table. I am leaning toward a band saw just because of the ease of use and walk away ability. I hate standing there holding the saw for ten minutes while it cuts, etc.
It would have to be a smaller unit, though.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Adjustment, cleaning, lubrication, and even modification are usually required with HF equipment. You buy the basic machine and everything else is up to the user. Kind of like kit cars...
Bootybug
Yeah, more of a stripped, not equiped philosophy--just to get the job done. I would prefer to have a lube device built-in.
Bootybug
BEAST.
And I agree; it's all Chinese these days. What do you think it's worth?
Bigger than I'd care for, but wth.
A_Pmech
IL
BEAST.
I'd buy that Kalamazoo at the advertised price long before I'd buy the significantly more expensive Jet.
The kalamazoo isn't a big saw at all, it's about 18" wide and 48" long. Weight is in the 300lb range if I were to guess.
sonnyboy
MN
My previous employer had an old (green) 4x6 Jet that was used for nearly 20 years in a 5 man tool & die shop to cut anything that would fit in it, including tool steel for injection molds. A few years before I started there in '97, it was replaced by a larger Kalamazoo. After that much use, the little Jet was relagated to cutting smaller pieces, as it was simply worn out, wouldn't cut straight and the blade would jump off often. The Kalamazoo was overall a pretty decent saw, and in my 10 years there, the shop more than doubled in volume of work, and it worked just as well as the day I started. While the Jet you pointed out may serve you well as a hobbyist, I don't think you would regret stepping up to a good used American made saw for similar, or less money. I've been kicking myself in the rear for almost 10 years for not picking up a decent Carolina Bandsaw for under $300 when I had the chance.
Spareparts
Lansing Ks.
Check ENCO.com they have a good selection of the Enco brand plus other brands, they also have free shipping on some products. If I was to get a new saw it would have at least a 3/4" blade.
mad57
hf band saw works great for me i cut everything with mine , dont knock it until you try it:)
saabman
Sebago Lake, Maine
Not to start a flame war, but Taiwan produces products that are a cut above the stuff from the Chinese mainland. Wilton, Jet, and Powermantic all come from the same place (WMH tool group) Wilton and Powermatic are regarded a step up from JET. But I dare say JET is a step up on the Chinese stuff from HF or Enco. Turn Pro from Enco is a Taiwan brand and a step up from there standard line.
Chris
Bootybug
I'm talking to them--shipping is high, unless I can use my shipper.
3/4 inch does give you more cutting options--just hard to find reasonably.
I need a tight tolerance of less than 1/16th of an inch--do you think I can get this thing in line with some work, if necessary?
cnc-me
MI
Regular old Skilsaw and a new carbide combination blade will work just fine.
Lightly coat the underside of the aluminum and the blade with Boelube or WD-40 for best chip clearing.
I can't believe you said that.:headscrat
Having rebuilt that nice Do-All of yours.:)
This is more what I expected.
Vertical bandsaw,coolant,course tooth blade, at a high rate of speed.
A_Pmech
IL
I save the bandsaw for contouring.
For breaking down sheets of aluminum there's nothing yet invented as fast or handy as a Skilsaw with a combo or non-ferrous blade and a can of WD-40!
Unless, of course, you have a shear big enough.
:D
mike13u
S.Florida
I think that you are not understanding what A Pmech original suggestion was, and yes, it is the cheapest and arguably the best. A regular wood cutting Skilsaw (also known as a circular saw) will cut aluminum just fine. Just follow his suggestions and buy a cheap one and your done. No need for those large saws for that cut.
Bootybug
Ok. I got that covered--for steel sheets and aluminum plate. Cutting thick rods within a 1/16 of an inch is the objective.
Seen this..
AD 105S 4"Capacity Portable Benchtop KAMA Bandsaw
Man, expensiiiiive.
mike13u
S.Florida
Again, use your inexpensive wood-cutting power miter saw for aluminum rod and tube. you will note a common theme...Those wood-cutting power saws work on aluminum!
Keep the blade waxed and cut away.
