Am I doing it wrong?
RivennHewn
PNW
Kicking up some dust in the shop this afternoon.
Wearing a mask fogs up my glasses.
How can they fog up my glasses if they aren’t letting air in and out around the edges?
I bent the nose to fit tight, but my glasses still fog up and I got dusty boogers in my nose.
Do these things work at all?
Or do they just give you a false sense of protection?
SALIV8
chicago and s/w michigan
Use a respirator. I use a 3m half face respirator with the disposable filters of my choice. Those crappy dust masks are useless.
The way to check for a good seal with these is put your hand over the exhaust port and blow. You’ll see if it is adjusted correctly and air tight. No glass fogging too. Lol
Ralf11
water evaporates off of your eyes and fogs up the glasses
cvairwerks
Within hearing distance of Texas Motor Speedway
The mask material allows airflow. Warm breath will tend to move to the top of the mask due to physics. You could try adding a band of tape on the mask near the upper surface, close to your glasses. If that doesn’t work, move to a half face respirator or a supplied air full face one.
Leaflessshadetree
Don't ask.
A drop of dishsoap on each lens, then wipe with a soft cloth.
Some masks (and respirators) fit better than others (depends on face shape).
Some have a metal band or wire to form to the shape of your nose.
Ever sanded drywall without a mask? Even a cheap ill fitting mask is better than nothing.
Renegade1LI
long island ny
If you really want to do it right you would get fit tested for the correct respirator and it would not leak around the seal to your face. When fitted correctly it should not fog up your glasses, just Google fit testing.
Kny21
US
Pull the glasses away from your face towards tip of your nose. It’s what I have to do when wearing a mask into a store and I’m not wearing contacts.
dcg9381
Austin, TX
Sometimes I wear a 3m respirator during Cedar season here.. They definitely work.
b-boy
Buffalo NY
Do you have any facial hair? If so, you're pretty much screwed with any mask and/or respirator.
cdestuck
Altoona, Pa
A friend bought me a box of these. Works great. No fog.
Jayman17
Seattle, Wa
The dust masks with the exhalation port are better for not fogging up glasses imo than those without. Problem is right now I haven’t been able to buy any due to Covid.
Jay
zak77
Monson, MA
Yup, respirator! I was cutting brick with an angle grinder dry yesterday and i had no issues with my glasses fogging up or nasty boogers afterward. Those cheap "masks" arent worth it.
