bubinga
Milton 796 1/4" MNPT D Style Coupler - Box of 10 $7.99​
s/s by amazon. hopefully it comes as a 10 pack not a single
Milton 650 1/4" MNPT x 1/8" FNPT Reducer Bushing Hose Fitting - Box of 10 $4.98​
Now It says "and air flow of 34 SCFM. Complete with a Buna-N seal. D style couplers and plugs are ideal for automotive application"
So is that like a standard air flow? That's not the High Flow type is it?
Fatboy148!
From SlickDeals. I paid $24.62 for mine back in 2020 when you couldn't get anything.
FoodSaver Plastic Jar Sealer for Vacuum Sealer Food Storage with Accessory Hose for Regular and Wide Mouth Mason Jars, White 9.00 x 6.00 x 4.90 inches​
4.6 out of 5 stars 26,698 ratings
3K+ bought in past month
$9.02 with 64 percent savings
List Price: $24.99
In Stock
https://www.amazon.com/dp/B016OL1AB6/?tag=atomicindus08-20
Your hand will get tired but yes, they will work with your Mityvac hand operated vacuum pump from the garage.....
Lowest price yet....
https://camelcamelcamel.com/product/B016OL1AB6
Dh3256
Here's a great deal at $15. It's a 10-pack, so about $0.30 per roll.
Scotch(R) 10457DS Electrical Tape, 1/2 x 240-Inch, 5/Pack, 1 of Each Color: Blue, Green, Red, Yellow, White, 10 Pack per Case
Only the title says it is a 10-pack, the part number and item description say it is one 5-pack.
If you really get two (or 10) packs it would be a great deal, but one pack is $12 from 3M, so you will likely be paying extra for a single pack, unfortunately.
M6erfan
'Merica!
Yeah, be careful, of this one, the wording may be misleading. It's 5 rolls most likely, not 50 rolls.
brandonsmash
I ordered that E-tape and requested delivery for this Thursday. Historic pricing suggests that it's generally about $85, which would line up with a 10-pack.
If I receive only a single 5-pack, it's going back.
bubinga
If you have the Walmart version of Prime or need some other things to spend $35.00 for free shipping, you can get the bottom set for $4.00 at Walmart!
M6erfan
'Merica!
What are you looking at part # wise? Scotch 10457DS shows on camel camel camel of having a high all time price of about $18. And that it is a one pack of 5 rolls. Unless I'm reading something wrong . . .
frampton
NY
I've been burned by Amazon several times for stuff like this. However, I ordered two of these (in separate orders) when the price dropped to around $20 and I received two 10-packs, so it's probably worth the gamble. It can always be returned.
M6erfan
'Merica!
Well price is up to $67, so maybe you'll luck out :dunno: GL!
srs2000
Stahlwille 05010060 55 Socket, Size 60mm, Hex Tip, Drive Connector 20mm (3/4”), High-Performance Steel & Chrome-plated, Anti-Slip Drive Profile, Ideal for Tight Spaces, L.80 mm
$2.20
$23.02 delivery ($112 on KC Tool)
  • FireShot Capture 027 - Stahlwille 05010060 55 Socket, Size 60mm, Hex Tip, Drive Connector 20_ ...png
cweidert03
New Castle, IN
I don’t know how to link to a post here, but saw this craftsman V series 3/8 set was 50% off. I don’t need it but thought someone may be interested. It’s listed on Amazon.
Craftsman V-SERIES Socket Set, Shallow MM, 3/8 Inch Drive, 18 Piece (CMMT45753V) https://www.amazon.com/dp/B0B5KH1ZS8/?tag=atomicindus08-20
Duker
Livingston, TX
Etchase
Hawaii
RACO 752 4 in. Square Box Cover, Flat, Blank, 50-Pack​
4.5 4.5 out of 5 stars 20 ratings
50+ bought in past month
Lowest price in 30 days
$3.78 with 90 percent savings
Typical price: $37.17
https://www.amazon.com/dp/B0196AN9XE/?tag=atomicindus08-20
I bought a box yesterday and today I got the entire box of 50 pieces delivered. Having said that, YMMV in 30ish days when they are available again.....
I received mine yesterday. I’ll find something to do with them for $0.08 a piece. The are quite heavy, and punched thru the inner and outer box, but I got all 50. They put the air pillows around lbs the box, but those pillows were deflated somewhere along the journey. Definitely a life time supply of these for me.
V
vwpieces
Hills, PA
My Raco 50pk arrived today also. Heavy little box. I am sure to use a Few of them in my lifetime for sure.
clip the 5% coupon and order 2 to get another quantity discount.
srs2000
  • FireShot Capture 028 - Amazon.com_ Stahlwille 51460003 Torque Screwdriver, Click-type, For T_ ...png
bas157
Near Philly
Etchase
Hawaii
Does it include the holders? says "Note: 1 pack of 20 2-inch Blue Quick Change Easy Strip Discs, the maximum speed is 20000. " and is listed under "Sanding Disc Backing Pads"
Always a question with Amazon. Pictures, description… frequently wrong. I’ll let you know. They are scheduled for Saturday Delivery. Either way it’s cheap enough. I have no problem if it’s not as pictured, or as described.
bubinga
hey, if nothing else, metal stock to make things out of.
bubinga
Well I won the 10 cent lottery - got 10 packs :cautious:
Pete
Wow! Good Job! I sure could have used a set of that tape about now.
Made a 3 wire TPS harness but about 10 feet long, to go from the TPS right to the computer with no splices.
But the wire should be Gray, Black and Blue. My new wire is Red, and black.
Would be nice to color code the new wires.
