Now It says "and air flow of 34 SCFM. Complete with a Buna-N seal. D style couplers and plugs are ideal for automotive application"Milton 796 1/4" MNPT D Style Coupler - Box of 10 $7.99
s/s by amazon. hopefully it comes as a 10 pack not a single
Milton 650 1/4" MNPT x 1/8" FNPT Reducer Bushing Hose Fitting - Box of 10 $4.98
Only the title says it is a 10-pack, the part number and item description say it is one 5-pack.Here's a great deal at $15. It's a 10-pack, so about $0.30 per roll.
Scotch(R) 10457DS Electrical Tape, 1/2 x 240-Inch, 5/Pack, 1 of Each Color: Blue, Green, Red, Yellow, White, 10 Pack per Case
If you have the Walmart version of Prime or need some other things to spend $35.00 for free shipping, you can get the bottom set for $4.00 at Walmart!
FloTool
10701 Spill Saver Multi-Purpose Funnel, Blue
4.6 out of 5 stars 4,722
6K+ bought in past month
$0.98$0.98
List: $2.69$2.69
FloTool
10714MX3 Super Funnel Trio
4.7 out of 5 stars 6,451
700+ bought in past month
Save 35%
$5.99$5.99
List: $9.19$9.19
Lowest price in 30 days
I ordered that E-tape and requested delivery for this Thursday. Historic pricing suggests that it's generally about $85, which would line up with a 10-pack.
If I receive only a single 5-pack, it's going back.
I've been burned by Amazon several times for stuff like this. However, I ordered two of these (in separate orders) when the price dropped to around $20 and I received two 10-packs, so it's probably worth the gamble. It can always be returned.Yeah, be careful, of this one, the wording may be misleading. It's 5 rolls most likely, not 50 rolls.
GL!What are you looking at part # wise?
A 60mm, 3/4" drive socket... "ideal for tight spaces"Stahlwille 05010060 55 Socket, Size 60mm, Hex Tip, Drive Connector 20mm (3/4”), High-Performance Steel & Chrome-plated, Anti-Slip Drive Profile, Ideal for Tight Spaces, L.80 mm
$2.20
$23.02 delivery ($112 on KC Tool)
RACO 752 4 in. Square Box Cover, Flat, Blank, 50-Pack
4.5 4.5 out of 5 stars 20 ratings
50+ bought in past month
$3.78 with 90 percent savings
Typical price: $37.17
https://www.amazon.com/dp/B0196AN9XE/?tag=atomicindus08-20
I bought a box yesterday and today I got the entire box of 50 pieces delivered. Having said that, YMMV in 30ish days when they are available again.....
My Raco 50pk arrived today also. Heavy little box. I am sure to use a Few of them in my lifetime for sure.I received mine yesterday. I’ll find something to do with them for $0.08 a piece. The are quite heavy, and punched thru the inner and outer box, but I got all 50. They put the air pillows around lbs the box, but those pillows were deflated somewhere along the journey. Definitely a life time supply of these for me.
Sounds too good to be true...Stahlwille 51460003 Torque Screwdriver, Click-type, For Torque-controlled Bolt Tightening, w/ 1/4" Internal Hex Drive, Capable of Anticlockwise & Clockwise Tightening, Safe & Accurate, 0.2-3 in.lb
$27.38 ($443 on https://hausoftools.com/products/stahlwille-51460003-775-torque-screwdriver-torsiomax-size-a-3 )
Mine has "shipped" but USPS hasn't scanned it yet if they have it. I know the name of the seller/store but I don't think I've ordered from them before.Sounds too good to be true...
Does it include the holders? says "Note: 1 pack of 20 2-inch Blue Quick Change Easy Strip Discs, the maximum speed is 20000. " and is listed under "Sanding Disc Backing Pads"The 6 holders are worth the money even if the discs are Junk.
TAIFAM 20 Pack 2" Quick Change Easy Strip Discs, Blue Strip Discs for Drill-Strips Paint, Die Grinder Sanding Disc to Remove Paint, Scale, and Oxidation
$6.70$6.70
Typical: $11.99$11.99
Looking like it does not. I didn't and do not expect me to... read into any or every deal posted. But thanks for looking out.Does it include the holders? says "Note: 1 pack of 20 2-inch Blue Quick Change Easy Strip Discs, the maximum speed is 20000. " and is listed under "Sanding Disc Backing Pads"
Always a question with Amazon. Pictures, description… frequently wrong. I’ll let you know. They are scheduled for Saturday Delivery. Either way it’s cheap enough. I have no problem if it’s not as pictured, or as described.Does it include the holders? says "Note: 1 pack of 20 2-inch Blue Quick Change Easy Strip Discs, the maximum speed is 20000. " and is listed under "Sanding Disc Backing Pads"
It's the Great Scotch Tape Gamble of 2023
I rolled the dice, here's hoping
Pete
hey, if nothing else, metal stock to make things out of.I received mine yesterday. I’ll find something to do with them for $0.08 a piece. The are quite heavy, and punched thru the inner and outer box, but I got all 50. They put the air pillows around lbs the box, but those pillows were deflated somewhere along the journey. Definitely a life time supply of these for me.
Wow! Good Job! I sure could have used a set of that tape about now.Well I won the 10 cent lottery - got 10 packs
Pete
