TxSteve
Granbury, Texas
"Tools Tested" on YouTube just did a foam cannon video and recommends the AstroAI brand as well as an identical rebrand by DBR:
I found the AstroAI unit is on sale for 15% off (clip the coupon), but you can also apply coupon code TG89O34V for an additional discount. My final price was $12.64
Ordered. That's a great price on a quality item. Thanks!
xOccupantx
Wait. Do I need a pressure washer to use this or can I just use my hose?
southalabama
Brewton AL
Thanks. I’m a bit slow. Took a few tries to get the promo credit discount but I finally succeeded
justtools
I bought one. the promo code did not work with my business acct but did work with my personal acct.
demarpaint
Long Island
Those promo codes can sometimes last for 30 minutes or less, depending on the size of the promo and how heavily it gets promoted. Amazon also rarely lets you double dip with a coupon and a code for very long.
Yes, I've had this happen before. I have a business account, so I logged out and tried my wife's regular account with no luck. I think the code might been timed out, or reached it's limit. I bookmarked the item.
Madjik Man
was $134 on BF, then dropped to $105 in january, now $88. at this rate it might be $50 by summer, but it's a pretty decent cabinet IMHO. first two went together quick and easy with no issues and if you need some cheap storage then this is perfect.
also have a white w/gray doors for $105 and another color for $119. version above says will ship in june but my other two had long lead times that were shipped much quicker than quoted, tho YMMV.
Finally got around to putting this thing together.
It’s really well packaged however mine had a dent on one of the panels. It’s one of the back panels so no biggie.
This thing is definitely lighter/medium duty. Nowhere near worth the $200+ regular price.
But at $88 it’s a no brainer.
Set a price of $100 on camelcamelcamel to wait to purchase another one.
ching0n
The two reviews with actual words (not just a star rating), basically read "Cheap, stay away". Just FYI.
you're not wrong. Mostly went w/them because it looks to be near identical (minus handles) to these that are well rated:
I'll update once I get them. I also considered these but the tip diameter was too big:
tabs
wv
might want to bump it up a couple bucks because i've seen it twice now at 105.** which i still think is a good deal. i mean it's like 100lbs...shipping has to be half of that even with a bulk discount.
srs2000
Wera 05003830001 8767 Torx Zyklop Bit Socket with Holding Function, 20mm x 60mm https://www.amazon.com/dp/B01BNIZSXQ?tag=atomicindus08-20
$5.13
8740 B HF Hex-Plus SW 5/32"x107 mm bit sock 3/8" drv https://www.amazon.com/dp/B07B7YX61N?tag=atomicindus08-20
$6.22
8767 B HF TX 20x35 mm bit sock 3/8" drv https://www.amazon.com/dp/B07B7XN2MM?tag=atomicindus08-20
$7.14
8740 B HF Hex-Plus SW 7 0x100 mm bit sock 3/8" drv https://www.amazon.com/dp/B07B7PLNFD?tag=atomicindus08-20
$7.58
WERA 05004924001 8767 B VDE HF TORX® Zyklop bit Socket, Insulated, with Holding Function, 3/8" Drive, TX 40 x 55 mm https://www.amazon.com/dp/B07X4HSWNK?tag=atomicindus08-20
$8.30
