Goes back.to.the revolution.Metric / SAE is a deep state conspiracy to make you buy 2 sets of everything.
Pete
Don't fall for Big Socket's propaganda.Metric / SAE is a deep state conspiracy to make you buy 2 sets of everything.
Pete
These are great. I wanted one of the Huots for years, then discovered the Vevor and couldn't pass it up for the price. I recently made inserts for mine (see the 3d print thread) as the square bottoms making fishing bits out of the edges difficult.Vevor 5-drawer drill bit / tap cabinet $46.82
Build quality is pretty comparable to new Huot.
Huot has dimples on top to facilitate stacking.
Vevor doesn't, but a non-skid pad does the job.
Vevor is about 1/4" wider/deeper so it sorta stacks with Huot.
Vevor has ball bearing drawer slides, Huot doesn't.
Vevor partitions are full depth, welded steel, immovable.
Huot partitions are plastic, removable (with effort), partial depth with bulk storage behind.
https://www.amazon.com/dp/B09987LKFN?tag=atomicindus08-20
Those look good and beefy. Unfortunately no coupon shows for me.Bondhus 33197 Set of 9 External Twist Socket Set 3/8" DR 8-19MM - Amazon.com
Bondhus 33197 Set of 9 External Twist Socket Set 3/8" DR 8-19MM - Amazon.comwww.amazon.com
Just randomly found these Bondhus Metric bolt extractors with an almost half off coupon. I ordered one and there's a couple left it says. $24.11 shipped
