Amazon Warehouse Deals
D
Duker
Livingston, TX
Since somebody liked the 2 x 72 belts.... Make your own Housemade Revolution grinder!
VEVOR Belt Grinder 2" x 72" Wheel Set, Complete Belt Knife Grinder Wheel Set, Aluminum Belt Grinder Wheel Crowned, for Knife Grinder 5" Drive Wheel 5/8" Bore 4" Tracking 2" Idler Wheels (5"-4"-2")​
zeug
Colorado Springs
vwpieces
Hills, PA
stillnostrebor
SW Missouri
You hooked me with this one...
I guess now I have to build a grinder.
darrowco
Los Angeles (California)
NSi Industries TORK 1109A Indoor 40-Amp Multi-Volt Mechanical Lighting and Appliance Timer - 24-Hour Programming - Multiple On/Off Settings - 120/208-277-Volt - Grey 2.9 x 4.7 x 7.9 inches​
Well, that did not work - came clean but was non-operational. The center disk spins freely on the shaft even the screw is tight. Plus, the center disk, when rotated by hand, trips the ON switch ok but something is bent/missing and there is no way to rotate past the OFF trip. The only way to switch off is by using the manual lever behind the OFF label. Can't win them all, back is goes!
jhelrey
MN
Received my Gearwrench socket set today. Brand new. Someone fondled it, but no grease, no signs of use, etc. Case could be a touch more rugged but the price was right.
MadWheelie
So I got the Grey Pneumatic Metric Socket Set today and it was just an empty case. I can't believe they would try and resell it missing all the sockets.
89MustangGX
Stanwood, WA
Wow. We've seen the products replaced with cheaper or worn out stuff, but who has the gall to return an empty case for a refund and then who at Amazon can't figure it out?!?
89MustangGX
Stanwood, WA
The 1" Milton pressure regulator came in. I actually thought that it was brand new as the box looked original and untouched, but upon opening it I did find a bag with a hole in it. I suspect it originally came with two plugs for the pressure ports on it, but only one loose in the box. No instructions either. But no evidence of it actually being used -- still paint on the threads, etc. Going to see if I can find a materials list to make sure I'm not missing anything, but I think it's a win.
D
Duker
Livingston, TX
BroncoAZ
