Crescent Lufkin 1-3/16 x 25' Command Control Series Black Clad Tape Measure - L1025CB
Regular $24.38 ($21 at Acme), used "very good" $9.92
https://www.amazon.com/dp/B07WP71GPH/?tag=atomicindus08-20
looks a lot easier to read damn getting old *****
Koch 201240 Tradesman Cable Puller, Double Gear and Double Pawl, 4 Ton
Brand: Koch Industries
3.2 out of 5 stars 5 ratings
Price: $65.20
Save with Used - Very Good $20.91
Item will come repackaged.
FREE delivery: Friday, Jan 29 & FREE Returns
Order within 3 hrs and 39 mins Details
Only 1 left in stock - order soon.
Sold by Amazon Warehouse and Fulfilled by Amazon.
https://www.amazon.com/Koch-201240-Tradesman-Puller-Double/dp/B002T44SAI/ref=cm_cr_arp_d_product_top?ie=UTF8
This deal is back, Iroda CT-610KB Blue Professional Butane Heat Gun Kit (Made in Taiwan)(Butane Not Included) Heat Gun Welding Brazing Torch Case Handsfree Stand. Currently 47.11 less 20 coupon for a total of 27.11, plus tax. I missed it when it was this cheap before Christmas.
Thanks, $29.75 with tax, figured I must need one.
My torch came in, looks solid. I've used propane and Mapp gas torches, but not butane. This needs the built-in tank/handle to be filled with butane. I don't know the terminology so search results are confusing on the refills, is "butane cartridge" or "butane cannister" the same thing as "butane refill"?
Will this work? https://www.walmart.com/ip/Coleman-8-oz-Butane-Canister-for-Portable-Appliances-Stoves/47501190
If not, please point me in the right direction to get the butane format I need.
They also had a 100’ hose for $22+ off so now I’m good on garden hoses for the springFlexzilla Garden Hose, 5/8 in. x 50 ft., Lightweight, Drinking Water Safe - HFZG550YW-E
Regular $31.98, used from $22.31.
I bought one on a Duker post and is was fine.
https://www.amazon.com/dp/B003TFE7ZM/?tag=atomicindus08-20
Based on past history...this one might not make it until tomorrow....
SK Hand Tools 6029 29-Piece Punch and Chisel Set
https://www.amazon.com/dp/B0002SR01M/?tag=atomicindus08-20
Sent from my iPad using Tapatalk Pro
I think you need this type:My torch came in, looks solid. I've used propane and Mapp gas torches, but not butane. This needs the built-in tank/handle to be filled with butane. I don't know the terminology so search results are confusing on the refills, is "butane cartridge" or "butane cannister" the same thing as "butane refill"?
