The only metric that’s ever caught on in the US is the 9 mm
And just a reminder
There’s two kinds of countries
Those that use the metric system
And
Those that have put men on the moon
And just a reminder
And
When I was in the United Kingdom not so long ago I tried to buy a imperial tap and die set- they told me they don't have it on stock and needs to order it because they use the metric ones also since years.
Yeah but with common core it will take you longer to come up with an answer than to try 4 different wrenches. [emoji23]
What do they say in metric countries in place of "What kind of mileage you get with it?" Miles per gallon flows off the tongue a lot better than liters per one hundred kilometers.
Then of course there is temps. Fahrenheit makes more sense to me, since 0°F is a really cold day, and 100°F is a really hot day. In Celsius, 0° is a little chilly day, and 100° is you're dead.
I agree, although 10mm is making a bit of a comback
Is that why NASA started using the metric system before 1990 then?
https://www.space.com/3332-nasa-finally-metric.html
If we have to adapt to the metric system to make things easier internationally, everyone should use English as the official language. No exceptions.
I'd gladly make that trade![]()
There will be those that will look it up , but I seem to remember metric, ISO, didn't standardize until 1972. If my experience with cars and machinery is anything to go on, each country had their bolt pitches.
What I don't like is I can't buy any metric tools at the contractor supply; only SAE. It's the only place in town that stocks Wright tools.
This is very true! The whole lumber measurement system is a huge mess. Very few things are 'true' measurements with lumber, except when you get into some of the man-made materials like MDF, where of course it is now true-size.
Canada is officially metric but just like Australia, we still get stuck with a mix of metric and SAE sizing depending on what the product is, mostly because the US is too stubborn to change and they control certain industries. And quite frankly, as much as I dislike the weird sizes of lumber, and measuring things in 16ths and 32nds, it would be quite a mess to overhaul the lumber system at this point.
Would you keep current lumber standard sizes the same, and convert to metric (a 2x4, which is actually 1.5x3.5, would be approx 3.8cm x 8.9cm true size), or would you make it a 4cm x 9cm and slightly change the standard size and call it a 4x9? But then what do you do when adding on to existing old-standard framing in a house?
I am just reserved to having to know both. It would be great to hit the reset button and start over with one clean system for everyone, but at this point I don't mind measuring and cutting my 2x4 to 360cm in length.
My problem is the lack of available hardware, fittings, supplies, materials and measuring tools available to us in metric.
I cannot purchase any common building materials, fasteners, or common machinery calibrated in metric.
We have a massive industrial legacy that would take decades to switch, and would cost billions of dollars, and even then would still be here in some ways.
I'll happily switch to metric when I can buy everything I need for a project in metric. From my steel sheet, to my fasteners to my welding wire to my hand tools.
Ever try to machine parts in metric when all your tools, equipment, and entire shop is set up to do a different type of measuring? Huge pain in the ***. You have to convert everything. Every. Single. Thing. Sheet metal is sold in gauge thickness, pipe in IPS and bar stock is all in inch.
Did nasa use metric in 1969?
You can buy most of that in metric, pretty easily too. My little podunk hardware store has a MASSIVE metric fastener collection. Metric supplies, fittings, etc.. are readily available from most industrial suppliers. The only one I've actually had a hard time finding is metric sheet stock.My problem is the lack of available hardware, fittings, supplies, materials and measuring tools available to us in metric.
You're doing it the wrong way. You convert the drawing's dimensions to inch, and then you're good. You can then measure and machine everything with your existing tools without having to convert again.Ever try to machine parts in metric when all your tools, equipment, and entire shop is set up to do a different type of measuring? Huge pain in the ***. You have to convert everything. Every. Single. Thing. Sheet metal is sold in gauge thickness, pipe in IPS and bar stock is all in inch.
Nothing wrong with 12.7mm pipe and hose. It's pretty common actually for European companies to mark their 1/2" products with that measurement. But you'd just switch over to standard metric sizing eventually anyways. 12mm,10mm, etc...Yeah, gotta love 1.27cm pipe.
Neither is easier if you're familiar with them. It would be a lot harder in many fields where historically, they've used freedom units.
The BWG isn't inch standard, nor does it follow any mathematical construct. It's completely arbitrary based on drawing operations for steel wire. Eventually the gauges were defined by numbers for standardization purposes, but they're just as arbitrary in inches as they are in metric. You could easily define a system rooted in metric numbers, and then label it something like size "A, B, C, D" or whatever to easily remember.In medicine the English Birmingham Wire Gauge is still used to measure needles and catheters because is is easier to use a sizing system of 00000 - 36 rather than a bunch of seemingly random metric measurements from 12.7mm to 0.1mm.
Much easier to say give me an 20 gauge IV than a 0.9081mm IV.
The very reason I consider myself fortunate to have been educated in the 1950s-1960s. I was taught math and arithmetic the right way.Yeah but with common core it will take you longer to come up with an answer than to try 4 different wrenches.
Agree 100%--but then I'm a former engineering student myself.I just wish people would stop the arguments of imperial being more accurate. That just makes you sound dumb, as neither system has inherent accuracy or lack-thereof. Besides, the inch is defined off the meter anyway. If dividing by two is easier than dividing by 10, great. Grab your 27/64ths and letter U drills and go town.
Im not sure what idiot thought up that stuff but its like doing every *** backwards..the answer is sooo easy to get if you do it normally but 10x harder to get their wayThe very reason I consider myself fortunate to have been educated in the 1950s-1960s. I was taught math and arithmetic the right way.I have seen common core problems posted on other forums, and all I can say is, why complicate it so much?
I wish the US had actually gone metric like I was told would happen back in 2nd grade.
If you are a civil engineer or contractor you no doubt have seen errors related to decimal feet (the units of land survey equipment and survey records) and ft and inches called out in drawings. Frequently a page of contract drawings will call out elevations in decimal ft while showing horizontal dimensions in ft, inches and fractions of inches. So people on the site might have both types of tape measures on hand. Next thing you know something that should have been installed at 5.3 ft got installed as 5 ft 3 inches.
There are 7.2 BILLION potential consumers outside of the US versus our 327 MILLION domestic customer base. While our antiquated units of measurement don't prevent people from buying our products, it does lessen the demand. So... increased sales and possibly more jobs?Provide a legitimate incentive to convert to metric, otherwise, shut up.
If you don't like the discussion, move on. I don't really know what makes you feel that you are the one who can decide what is a worthwhile discussion.Provide a legitimate incentive to convert to metric, otherwise, shut up.
Are you obtuse on purpose? Everything. Have you noticed how even American designed cars use mainly metric fasteners and engines are measured in liters? Aircraft are designed in metric units, etc. Those industries are prime examples of adapting to a global market place.And what products would those be?
Calling someone who doesn't work with fractions every second of their life a "mental midget" is ridiculous. Someone shouldn't have to remember every combination of fraction to do quick math. The beauty of base 10 metric units is that the math is inherently easy to do. You don't have to rely on tricks and memorization.
Are you? You made the insinuation that, our "antiquated units of measurement" "lessenthe demand" for products. I asked you to provide an example, and you provide an example that, in your own words, has already adapted? Seriously, and you're asking if I'm the obtuse one?
Unfortunately, I can't speak monosyllabically enough for you, but I can speak in plain English:
Provide an example of a product that supports your supposition that, as it currently utilizes Imperial measurements, would see an increased demand were it to convert to Metric measurements.
