Wamsutta
Is it necessary for a backing pad and a sanding disc? The reason why I ask is because I think I could use more surface area of the sanding disc if the guard wasn't there.
I think he's just referencing resin fibre discs, but maybe he's also sanding. Either way an angle grinder with a resin fibre disc does a great job.One angle grinder is the wrong tool for sanding. A DA sander is what you need. They’re designed to run flat, or nearly so, and won’t take off and attack your testicles.
If you’re talking about those discs that look like impregnated horsehair, I have a couple, but I usually use the drum type that Eastwood, HF, and Amazon sell. They promote them as metal surface finishing tools.I think he's just referencing resin fibre discs, but maybe he's also sanding. Either way an angle grinder with a resin fibre disc does a great job.
I leave the guard off mine for a resin fibre disc. And always on for zip/grinding wheels
And I always wear a face shield for any of them
I don’t think I have touched the 9” grinder in ten years.Nobody's asked the money question here. 4.5" grinder? Sure. I keep 5 or 6 around and keep the guard on for wire and grinding disks. I have one with a flap and no guard.
9" grinder... no way.
Also, I always wear long sleeves, gloves and a safety shield or my welding helmet in grinding mode. I try not to use my welding helmet, but if I'm sanding or wire wheeling between welds I will do it.
It scares me. At least now that there’s an internet connection in the shop I can call 911 even though there’s no cell service.
All my guards are in place.A surprising number of assumptions go into the statement "I can call..."
Fingers intact? Phone in reach? Voice commands and a voice? Sight still intact? Conscience and functional?
There are some jobs I no longer do alone.
As for a grinder - 13k rpm doesn't leave you much time for "hmm, maybe I should have left that guard in place".![]()
Can’t do much better, except to sit in the house and watch tv all day., or maybe have the local EMS parked in the driveway on standby.
They are fibre sanding discs. Used basically anywhere you would use a regular flapwheel, maybe not as good on inside corners etc.If you’re talking about those discs that look like impregnated horsehair, I have a couple, but I usually use the drum type that Eastwood, HF, and Amazon sell. They promote them as metal surface finishing tools.
On the grinder, I like flap discs for most uses, although I picked up a couple of the $20 Porter Cable cheapie grinders to add to the grinder armada specifically to have the fiber disc ready to go.
One reason to keep the guard on is that it keeps the work area cleaner, and, to some extent, localizes the mess. The other reason is that I don’t have to wait for the disc to stop before setting the grinder down. That couple of seconds of spin down time annoys me to no end.
I use them occasionally on air tools. There’s a stack somewhere in the shop but they’re not a go to disc for me. My stock is probably twenty years old. I don’t think the air ”grinder” even came with a guard.They are fibre sanding discs. Used basically anywhere you would use a regular flapwheel, maybe not as good on inside corners etc.
Usually gettem in 25 or 50pks. Ends up being a fraction of the cost of running flap wheels and they last pretty damn good.
Where do you put the guard on this? Certain discs require guards, certain discs are ok without. Use a face shield and preferably glasses as wellI leave the guard on 99% of the time. I will admit there is an occasional time were the guard is in the way and I will take a chance and remove it, but it goes right back on.
To those people that never run a guard, have you never had a cut off or grinding wheel come apart? I have had a couple fly apart and I was glad the guard was in place. There is a tremendous amount of power released from a grinder spinning at 10,000 RPM!
I've had one cut-off wheel explode on me--but that was in a die grinder. Yes, it was bad. I got a new ear-piercing from it.I leave the guard on 99% of the time. I will admit there is an occasional time were the guard is in the way and I will take a chance and remove it, but it goes right back on.
I don’t buy cheap abrasives so it’s far less of an issue with the good discs. Damaged wheels get thrown in the garbage. Cheap abrasives self destruct if you look at them wrong.I leave the guard on 99% of the time. I will admit there is an occasional time were the guard is in the way and I will take a chance and remove it, but it goes right back on.
I have seen that style of air grinder with a guard. If I bought one it would have to have a guard.Where do you put the guard on this? Certain discs require guards, certain discs are ok without. Use a face shield and preferably glasses as well
Whether it's the wheels fault or not, if it comes apart, it can cause pain and injury.I may have had one cutoff wheel come apart in the last 15 years or so and that was my fault, not the wheel or the grinder. I was using a chipped wheel and I knew what could happen. No big deal.
But do you think IR would make it and sell it without a guard if a guard was required? It spins at 18k rpm...I have seen that style of air grinder with a guard. If I bought one it would have to have a guard.
The backer I run is an extra firm Bosch backer. It's real stiff but feather light. It's the only backer that works good with my Bosch grinder.I don't run a guard with sanding discs running on the plastic backer, guard always gets in the way, it's corners rubbing on what you are sanding.
I have had the backer blow up once on a 6" size disc, turns out it wasn't rated for the 36 grit discs we were running, who knew they made them rated for different grit grades.
Seems crazy to me. Looks like a lawsuit waiting.But do you think IR would make it and sell it without a guard if a guard was required? It spins at 18k rpm...
No they would not.But do you think IR would make it and sell it without a guard if a guard was required? It spins at 18k rpm...
What about a 3" roloc ScotchBrite disc or they also make fibre discs on a right angle die grinder, also need a guard?Seems crazy to me. Looks like a lawsuit waiting.
It's hard to imagine the specifics because you have no specifics, BUT, you should have the guard. There are hundreds of ways to have an accident - like something getting caught that is in the near what you are doing.Is it necessary for a backing pad and a sanding disc? The reason why I ask is because I think I could use more surface area of the sanding disc if the guard wasn't there.
