Jswain
I think the grinders are known to be if not the worst then very close to the worst on battery run timeI've done lots of projects with M18 grinders. They last a long time on a battery.
Dunno.I think the grinders are known to be if not the worst then very close to the worst on battery run time
Dunno.
I built a whole exhaust for a truck a month ago, roughly 20hrs of work with 3 batteries. Lots of cutting and grinding the aluminum coating and some rust (used old 4" tubing for part of it.)
Probably 5-6 hours of grinder use altogether.
Possible other flavors work better, I'm satisfied with that though. Actually bought 2 more so I don't need to change wheels as often. 1 for grinder wheel, 1 for cut off, and 1 for flap disc.
How many batteries do you have? Because you certainly aren't getting far grinding with 1, nor anything in the small amp/hr range....you're looking at a few bucks to get into something that honestly other then a quick job leaves a lot to be desired.
And agreed on spending more $$ on consumables that makes a huge difference, especially with the balance on wire wheels etc., The good stuff pays for itself usually.
I dont think a lot of posters on here understand just how much power is in a modern name brand battery like Milwaulkees or Makita or DW. Or theyre compairing them to the old NiCads or off brands like Harbor Freight.I've done lots of projects with M18 grinders. They last a long time on a battery.
My smallest die grinders have no paddle safety, but I wouldn't count those, even though they scare the **** out of me sometimes.Lucky you I guess??
I can’t say as I’ve ever seen or heard of anyone else doing it but I guess it’s possible.
Won’t change my opinion that they’re a better design for when a cutoff wheel snags or if you accidentally have a wire wheel get caught or something. Dead man’s switch is much safer than a switch. I’ve seen switched grinders take off to the end of their cord and wreak all kinds of havoc when the operator loses their grip.
Anyone actually reading the text these days?Planning to purchase a 4 1/2" angle grinder for cutting both rebar and block with appropriate blades. I don't need cordless, and have a good compressor so pneumatic is an option as well as corded electric. A couple of projects. A lifetime everyday tool I'd definitely not required. Have to wonder if the ones from HF will last.
Thank you in advance.
Dude is waffling on HF or likely the next cheapest grinder available (or chewing through it with his teeth)
Does not care about battery run times or top of the line grinders![]()
Metabo (made in Germany) is not on the same playing field as Hitachi HPT (POS). Metabo makes fantastic grinders, at a price, and they are a pleasure to use. Don't think that Hitachi is even remotely the same quality as Metabo.I'm a casual user of a Hitachi/Metabo. It's been good to me so far.
Thanks but I'm probably guilty of thread drift as well. The folks who wear out HF grinders but their others keep going - wear out in days, weeks, months...? And cutting block - do you really want to expose an expensive corded tool to that much fine dust or sacrifice a cheapy?Anyone actually reading the text these days?
Let's face it - we all love to spend other people's money.Pretty typical for here.
OP posts he needs something for a few small jobs, doesn't need a lifelong tool.
GJ reads "OP is going to be a career welder, I should suggest the most expensive angle grinder known to man, only to be somewhat decent if he spends even more hundreds of dollars on expensive batteries, once he gets the grinder and complains about battery runtime I'll **** him in for a hypertherm & 80gallon compressor...I'm sure he'll need those too" LOL
That's good to know but as a casual user I literally didn't care then and don't care now.Metabo (made in Germany) is not on the same playing field as Hitachi HPT (POS). Metabo makes fantastic grinders, at a price, and they are a pleasure to use. Don't think that Hitachi is even remotely the same quality as Metabo.
I also like my Makita, Bosch, and 6 or so Harbor Freight. Out of 15 or so grinders, I prefer the Metabo 1st, then Makita. The HF at $15 ea means you can buy one for each type of abrasive, which is very handy.
P.S. You do NOT need to be a pro to need something bigger than a 4.5". This comment makes no sense. The Black & Decker Wild Cat is a nice beast and I have used it many times every year for 20+ years. My Makita 6-in variable speed is also used a ton. I am no professional, but not a typical DIY either.
I am glad that you have had good luck with your Hitachi HPT products. Maybe I got a dud, who knows. I have had 2 batteries fail on an Hitachi HPT within 9 months of very very mild use. I have not had a HF (corded) fail since I bought my first one over 20 years ago. I'm not a brand name snob. That ranks as a POS in my book, price being a consideration.That's good to know but as a casual user I literally didn't care then and don't care now.
I'm probably a little bit like the OP. A decent grinder that doesn't irritate me to use is fine thanks.
And no it's not a POS.
Apples and oranges, man. Hitachi is trying to take advantage of the name and reputation Metabo built making the industry standard of grinders for years and slapping the name on the cheap grinders you buy at the box store. It kinda reeks of slimy sales tactics, almost a bait and switch.That's good to know but as a casual user I literally didn't care then and don't care now.
My Hitachabo is corded. It's not really fair to compare a battery product to a corded product.I am glad that you have had good luck with your Hitachi HPT products. Maybe I got a dud, who knows. I have had 2 batteries fail on an Hitachi HPT within 9 months of very very mild use. I have not had a HF (corded) fail since I bought my first one over 20 years ago. I'm not a brand name snob. That ranks as a POS in my book, price being a consideration.
I never heard of Metabo when I bought it. I just needed a grinder. I'm not aware of any misrepresentation.Apples and oranges, man. Hitachi is trying to take advantage of the name and reputation Metabo built making the industry standard of grinders for years and slapping the name on the cheap grinders you buy at the box store. It kinda reeks of slimy sales tactics, almost a bait and switch.
While HPT stuff isn't bottom of the barrel, it certainly is NOT the same as the German made Metabo stuff they so desperately want you to think it is.
While it may not be a POS to you, it certainly feels like one when you're used to using industrial grade grinders. At least DeWalt, Makita, Milwaukee and other box store brands are not trying to misrepresent what they are.
I haven’t worn one out yet. One of mine the casting broke where the side handle is attached, and the bearings sound rough, causing a little vibration. It still gets the job done, but it’s likely on borrowed time. This is the first one I bought. The only other problem I have had is that cord failure I mentioned in my earlier post, which I fixed by shortening the cord. Based on my experience, you can probably get the jobs you want to do, done with one. Try one, you’re only risking $15-$20.Thanks but I'm probably guilty of thread drift as well. The folks who wear out HF grinders but their others keep going - wear out in days, weeks, months...? And cutting block - do you really want to expose an expensive corded tool to that much fine dust or sacrifice a cheapy?
I wonder how much of that vibration is the grinder, and how much are the cheap abrasives.Valid points but carpel tunnel is forever and the vibration of the cheapest HF grinders and cheap *** accessories (Warrior) are legendarily bad.
The fact you thought it was generic is why the Metabo I.P. is so valuable. Pass me the Kleenex?I never heard of Metabo when I bought it. I just needed a grinder. I'm not aware of any misrepresentation.
I actually thought Metabo was generic. It was just a grinder in a box on a shelf with a case at a price I was willing to pay.
It's really not that complicated.
Most of it. If the grinder vibrates return it. No problem running my cheapies all day with decent abrasives and no vibrationsI wonder how much of that vibration is the grinder, and how much are the cheap abrasives.
OP has plenty of answers to make a decision. Deep dives into minutiae make threads interesting. OP may not need or want anything more than a HF grinder, but other people read these threads and may get some information out of it.By the way, we need to keep it in context here. OP made it clear he isn't an industrial user.
Just a point of order. Metabo HPT (Hikoki in the rest of the world) DOES NOT EQUAL Metabo especially with respect to grinders. One is a cheap Lowes brand and the other a top of the line industrial grinder.
