Anodizing cast aluminum
JackOfDiamonds
Idaho (USA)
I routinely anodize 6061 aluminum, but I'm working on a project now that uses Alcoa "MIC6" cast aluminum tooling plate. I would like to anodize this because it's just so much nicer than raw aluminum, especially screw threads, but I don't know if it will "take". Has anyone tried it?
CapriMikeC
If you are anodizing simply for corrosion protection, then yes it works well. Especially with Type III hard anodize it will give a kind of olive/gold color.
Any threads that get anodized need to be slightly oversized since the pitch diameter will shrink with the anodize buildup.
PCustoms
VT
Mechanically/chemically it will work.
Cosmetically it's a tossup, and will likely be blotchy to to the variations on the casting. I've got a lot of cast parts that get a non-cosmetic anodize and the finish is all over the place.
klxrcr
Missouri
I’ve had mic6 anodized that had what appeared to be “flakes” that didn’t take the dye. It was pretty noticeable when anodized black. You should use alca-5 tooling plate if you want to anodize it, it’s a 5000 series aluminum so slightly less yield strength but it looks better and I found it to cost less than mic6.
J
JackOfDiamonds
Idaho (USA)
My other option is "Gleich g.al C250". It's another cast aluminum but the website seems to indicate it's a 5000 series alloy. I'll have to read up on what 5000 series actually means. I gather the problem with MIC6 is the high silicon content.
EN AW-5083 [AlMg4,5Mn0,7 – 3.3547]
MoonRise
5000 series aluminum refers to the aluminum alloy 'family'. 5083 is obviously in the 5000 alloy family.
5000 series has magnesium as the main alloying additive, and is a non heat treatable aluminum alloy, but the alloy can be hardened/strengthened via strain hardening or cold working. It is a "wrought" alloy and not a "casting" alloy (the casting alloys use/follow a different alloy designation format with three digits instead of the four digits used to designate the wrought alloys. The casting alloys with magnesium as the main alloying additive would be a 5xx designation compared to the 5xxx designation for the magnesium wrought alloys.)
Alcoa MIC-6 plate is listed as a 7000-series aluminum. One data sheet says that it is able to be anodized and welded, but other data sheets recommend Alca-5 because it is a little STRONGER (18 ksi yield versus 15 ksi yield, and 41 ksi UTS versus 24 ksi UTS) and anodizes better than MIC-6. And is supposed to be 5% lighter too, if that matters.
Alcoa MIC-6 data sheet:
claims that MIC-6 can be anodized successfully to a dark grey but often shows color and/or texture variations in the anodizing from the casting process. But that dying it black after anodizing usually results in a good cosmetic appearance.
