Another 2 post lift
JamesDandy
Hello all!
I finally am getting my garage built, and I looking at two post lifts. Specifically I want a lift capable of a 1 ton truck. Everything I have read says 12K and I am contemplating the AMGO OH-12S. I had two 4' squares poured 12" thick in the floor for a lift and I have 14' walls. Any suggestions? I have not seen many lifts in the 12k weight that are short enough for 14' walls.
Thanks in advance,
JD
finn
The UP, God's country
I lifted my old F350 dually crew cab pickup on my 10k BendPac a number of times without issue.
It did make me nervous, and would have been nice to have longer arms, though. Typically I only lifted the dually high enough to comfortably do brakes, wheel bearings, and tires.
I suspect a 12k lift might have longer arms, but never checked that.
Hohn
Diesel Central, Indiana
Wise observation that there's more to a lift than just its stated weight capacity. There might be other good reasons to want a larger lift.
charbar
Midwest
I've used an Amgo OH-12S almost daily for the last few years for 3/4 and 1 ton pickups. No issues with the lift, I just wish the arms sat a little higher when on the top locks. Might not be an issue for some people, I'm just over 6 ft tall and it can be annoying at times. I can walk under my 10K lift arms with no issue but the OH-12S puts the bottom of the lift arms about smack dab eye level on me.
My 10k lift is pretty stout compared to a lot of other 10Ks but the OH-12S is way beefier. Much more solid feeling when you have a crew cab long box diesel with a bale bed and a 9 million pound replacement bumper/grill guard hanging off the front. The longer three stage arms are ALMOST a must in my opinion too. Especially if you are going to be lifting earlier Ford Super Duties that have the long tall angle in the frame behind the cab.
Extra tall jack stands are a nice piece of mind also when you have that much weight wobbling around trying to hammer out wheel bearings, pull transmissions, differentials, etc.
charbar
Midwest
Look at Atlas lifts.
Atlas and Amgo are both made by the same company last I knew (Peak I believe it's called) I've had and have been around plenty of Atlas lifts, that is why I wasn't scared to try an Amgo. Hell my current 10K Atlas even says Amgo on the door bumper pads (bought the lift new) :lol:
FTG-05
TN
Hello all!
Thanks in advance,
JD
If you're lifting a truck with the fuel tank right next to the frame rail, invest in a pair of these:
Features and Benefits:
  • 1 Pair of Frame Adapters for 2-Post Lifts
  • For use with certain vehicles with the Gas Tank or other obstructions near the frame
  • 1.57? Peg Size
The optional frame adapter set (2 pieces) is available for a two-post lift with 1.57 inch adapter holes. These special saddle adapters (used on the two rear arms in place of the standard round lift pads) are designed specifically to provide a secure lifting surface for those trucks that have the gas tank mounted VERY CLOSE to the frame. Many trucks and even some SUVs have the gas tank located so close to the frame, that makes it almost impossible for the standard lift pad to have full contact with the frame. This saddle adapter set allows the frame to "sit inside the saddles" and provide a superior lifting surface. This frame adapter set works well with certain Ford ®, Chevy ®, and GMC ® pickups and SUVs."
Make sure your peg size is compatible with your lift: 1.57" (like my 12k lb Atlas/Direct Lift), 1.5" or 2" (typically).
I didn't have these the last time I lifted my F-350 PSD. Never. Again. :eek:
Jetfixr320
  • 1.57? Peg Size
My Atlas lift came with them
finn
My BendPak has the circular pads for unibodies and the channel pads for full frames.
i ordered additional risers as I ran into issues with the arms contacting the side steps on my Super Duties.
the risers come in several pin sizes, so measure before ordering.
