jgonz123
Many questions were answered by reviewing old posts re:modifying garages for storage above joists (or trusses). I did this at my previous house by blocking between the 2x6 joists and putting 1/2" plywood on top -- that garage was only 19'x25 with rafters and large ridge board. I also sistered the entire length of two 20' 2x6 rafters and glued/bolted them together where I would be putting most of the weight (mostly rubbermaid bins with clothes, odds/ends -- nothing heavy, but it does adds up).
So I purchased a 1967 home with a huge garage (28x34) ready to repeat the process. But this attached garage doesn't seem as sturdy as my last.
Since I'm not storing any thing heavy (engines, concrete, etc) just Rubbermaid bins,suggestions?
I was thinking I'd sister two 18' 2x6 together so they overlap each other 4' at center (glue, bolt/nail) and put two of them between each 54" space (next to each rafter as it meets the wall plate) and gusset.
I should attach them to the rafters near their center?
Here are some pics, have lots more.
- Joists are only 2x6 for 28' width and are a whopping 54" apart -- there are only 6 total. I had more at my small previous garage.
- Rafters are 18" but they attach to a thin (1x6?) ridge board across the long roof length.
- Every other has W shape supports from the rafters to joist with ply gussets support and also at edges near the plate.
