Another new floor coating question...
Automobilist
Snohomish County, WA
My new shop is about 90% done, and I want to "seal" the concrete floor.
Last shop I had, I applied a single-stage "epoxy" coating. Two coats. It went over Kemiko acid stain. That epoxy coat was terrible. Scuffed and scratched immediately. Looked really bad.
This time, I'm not staining the concrete. I want a clear finish, like a medium - dark gray. I think the epoxy with flakes look is getting somewhat dated, so just a nice simple finish. Also, not interested in tiling the floor.
Suggestions for a good looking coating that will hold up?
Armorpoxy
Take a look at our SPGX clear 1-part polyurea. Very well priced and easy to apply since this is a 1-part, no mixing product. Gives the floor a 'polished concrete' look, but with the resistance of urethanes.
Garage Flooring
Grand Junction, CO
If you want simple gray coating something like https://www.garageflooringllc.com/simple-no-odor-garage-floor-epoxy/ would be great. You could also do two coats of clear polyurea. In both cases I would suggest an anti wear additive in the final coat. Just drop me a pm if you want a quote
https://www.garageflooringllc.com/polyurea-garage-floor-coating/
Armorpoxy
No, it does not unless your floor is very porous or has other issues.
LegacyIndustrial
deerfield, IL
PRIME, PRIME, PRIME....
Looks better and leaves you with more mils on the floor.
Any coating going over a properly prepared surface is almost always a (2) coat process unless you like a splotchy surface.
A
Automobilist
Thanks...
I'm frankly confused at this point... Already over budget (of course...) and not really thrilled about spending a lot of $$$ on the floor.
I know, you get what you pay for.. But I'm hoping I can get a decent finish for under $2500, if I do it myself.
I wish I could just have someone reliable tell me exactly which product to use, how much to order, without all the interpretation of various products.
I don't mean to insult the vendors here, but really, everyone says their product is the best, without really saying why.
When potential customers contact me, I tell them exactly why our TransFueler's are the superior product, clearly and simply.
Armorpoxy
Contact us directly at below please with square footage so we can respond to your questions with pricing. Thanks!
LegacyIndustrial
deerfield, IL
Thanks...
This forum is great, but for detailed info your best bet is an email or phone call direct to the source.
Garage Flooring
Grand Junction, CO
Thanks...
You will almost never here me say that my product is the best. Legacy has darn good product, so does Armorpoxy and many others in this forum. This has absolutely NOTHING to do with what is best and everything to do with the best option for you.
You have thrown a budget number out there but I don't see square footage so it is very difficult to give detailed info. I may have missed it. If so I apologize.
I keyed in on simple and no flake. We have several great options for that. If you simply want to seal it we have some great sealers too.
FJ4FUN
NorCal
At one end of Wolverine Coating product spectrum we supply AcryliSeal 3501 which is a low cost water based sealer. Plan on having to re-coat every 4-5 years but super simple to apply and it is tough as nails considering it is an aqueous sealer.
For a more durable (but not fancy...) coating I'd throw a solid coat of our BondTite 1101 primer followed by a coat of our EnduraShield 2254 with or without SpheriTex traction additive over a properly prepped slab.
I'd need actual project square footage to specify quantities.
