Another Valve Cover Lamp
AffableCurmudgeon
Triad Area NC
Rick B.
East Tampa
Very nice. Wish we could see how the bulbs are attached underneath. Or is it a small fluorescent fixture?
A
AffableCurmudgeon
Triad Area NC
One 60 watt eqv. led candelabra base bulb. Picture attached. You can add as many as you like.
Toggle switch in one of the lug holes in the rotor.
A
AffableCurmudgeon
Triad Area NC
Wow..... more detail please
Well, Not much for tails. Pretty simple actually.
From my local junkyard, I got a valve cover from a Ford, a cam shaft from a Nissan, a cam drive gear from another Nissan and a rotor from the junk pile. Cleaned all the parts with a degreaser. Painted the rotor and valve cover.
I welded a bolt to one end of a camshaft, welded the cam gear to the rotor from below. Grounded the other end of the camshaft so that it fits snug in the oil fill hole of the valve cover. I put the welded bolt end of the cam shaft through the gear and rotor and put a washer and nut.
Attached a candelabra base to the underside of the valve cover using one of the three bolts on top. Wired the lamp through the rotor using one of the lug bolt holes for the toggle switch. Put on a cheap breather filter on the valve cover. Glued on the oil fill cap.
Put on few coats of clear coat on everything. That's all. Hope it makes sense.
ducksface
I'm not a fan of the genre, but that is the nicest execution I've seen on a valve cover lamp.
That's a really nice job.
LXCam
Most excellent. Might I make a suggestion?, too late I'm gonna anyhow ;)
Have the cam drilled or if you can do it yourself even better, then hide that wiring. Or maybe install a brass tube as a chase. Other then the exposed wiring it is with out a doubt a very clean looking unit.
kbs2244
I don't think I have ever checked.
But don't cams have an oil galley hole through them for oil to the bearings?
(I am sorry, but the exposed wiring just gives a "un-finished" look to me.)
(I would try and use the fill cap or the vent filter as the switch control as well.)
But then, it is easy to criticize other peoples work.
That is something I just would never do.
I am not an artist.
LXCam
I am not an artist.
Some do, most don't and like pelican said, most cams are as hard as a honeymoon ****. I happen to have a couple stock Hemi 5.7 cans here that are line bored so that part would be a cake walk to pull off. But I like the idea of the stainless tubing, that'd really make this pop.
A
AffableCurmudgeon
Triad Area NC
Added a chrome tube for the wire. No more exposed wires. Thanks for the comments.
jocww
Heres mine started yesterday. Making it for father's day
Sent from my SM-G935V using Tapatalk
jocww
These sure are getting popular. I got the idea when I saw it in Autoweek.
jocww
Done. Not as nice as the ops. Painting all the letters was a pain. Not sure how you did it. I did a little patina with coffee grinds over night. Then brake fluid and some burned on 5w30.
