Another Victim
Downwindtracker 2
BC
OK, you guys, you got another victim. I was going to fill in my 1/4" SAE sockets, mishmash picked from the clearance bins, instead I bought some Gearwrench. A rail of 6 points, a wobble extension and a this is really your fault, a 84 tooth flex-head. I have three small Mercury outboards from the 70s that are next in the project line.
Thanks Guys, these are nice
jd_1138
NE Ohio
Right on, life's too short for **** tools. Quality tools are pretty cheap these days relative to like 100 years ago. Do you have the swivel head ratchets? HF Pro versions are great especially for their cheap prices (like $10 to $12 each). I use the heck out of mine.
sberry
Brethren, Michigan
Tis is so common and used so much its part of a good tool set you probably should have had a long time ago. I don't use it every bolt, but there are places its the right thing. I prefer to use as big as I can.
D
Downwindtracker 2
BC
I'll have to check Princess Auto, a HF type store and more, for a pivot head. I had a Craftsman round head fine tooth and a ITC, a Proto copy, 1/4" ratchets.
Now, I have sockets with real indents! I didn't like the Gearwrench deeps, though, They're not broached any deeper than a standard socket.
jd_1138
NE Ohio
Yeah you will like the pivot heads, as once you break a fastener loose, you can turn it into a screwdriver and zoom the fastener out in a hurry.
619DioFan
San Diego , Ca.
I have this in 1/4 inch drive. one of my favorites.
D
Downwindtracker 2
BC
You guys just keep adding on don't you, chuckle. I think that's a baseball term. I don't get to hear it much with the Blue Jays. I amazoned a Tekton set of deeps and a pivot head ratchet. Just as well, I didn't do Princess Auto, it is like Costco, one of those places where they don't let you leave until you spend a $100.
After reading the posts on 1/4" ratchets , I could see how much more the 1/4 is now used, Gearwrench sockets went up to 9/16 .
