Indexmill
Hi Everybody,
What is the general consensus; do you use anti-seize on lug studs/nuts, or not.
This is really how it is. Also if you do decide to use antisiez than make sure as mentioned above to adjust the torque specs for the studs or lugbolts.You'll find there's no consensus...half the people do, half don't. It's usually split between people who live in the rust belt and those who live in southern states.
NO! Read the label.Hi Everybody,
This. Reduce the lug toque to compensate for wet vs. dryI also use a very light coating of it, not only on the studs but on the hub in order to keep the brake drum, rotor, and wheel from seizing to it. I have been doing this for the past 35 years on dozens of vehicles with no ill effects.
That's where I use it. Living in NY [rust belt] kicking wheels off can be a real PITA, especially if you're stranded with a flat tire.Even if you don't use it on the lugs, it can be helpful to use around the center hub. This can keep the wheel from getting stuck.
Depends on what.I'm in the rust belt and don't. You should be rotating or pulling off tires enough that it's not needed.
I went out to the garage and looked at 3 different bottles.NO! Read the label.
I leave most of them dry, but if I can feel them getting tight will use a very small amount. As to the hub: we have a lot of very high mileage vehicles and trailers with aluminum wheels and the damage from corrosion at the hub face is common and constant - especially for those that travel South and East in the winter. Some can become nearly impossible to remove for roadside tire repair. Years ago I started cleaning the hub faces up and spraying with a coat of zinc rich paint ("cold galvanizing" compound) and we no long see wheel pitting and they remove easily from the hub.I also use a very light coating of it, not only on the studs but on the hub in order to keep the brake drum, rotor, and wheel from seizing to it. I have been doing this for the past 35 years on dozens of vehicles with no ill effects.
WOW, i have never needed to do this to any of my Subaru's. May i ask what models?Yes I do. Used to not till I started working on Subaru where the studs always freaking snap lol. Can’t tell you how many I replace on a weekly basis. But I use very little. Just a dab of it.
In a commercial shop, I'd go with the "1 drop of oil" thing before I'd put antiseize on lugs when the product instructions specifically say don't do it. If there's ever a problem and some attorney gets that detail, you might get stuck with something that's not even your fault.Yes I do. Used to not till I started working on Subaru where the studs always freaking snap lol. Can’t tell you how many I replace on a weekly basis. But I use very little. Just a dab of it.
Ayuh,..... I use Form-a-Gasket #3 to seal out the water, 'n Ox so they can't rust on,....Hi Everybody,
