Unless specified otherwise, torque specifications are based on dry threads.
Will the Lugnuts work their way loose with lubrication on them? Maybe maybe not
Any time I've seen stuff on wheel studs I clean it off. We hand torque wheels at work, if that stuff is on there you have to keep tightening the lug nut till you hit your torque. It could be more then 360* more then dry threads. What do you think that's doing?
Yep, stretching the studs.
Wifes Mercedes has wheel bolts with Female threads in the hub. (it's fun getting the wheel on)
I do always use a wire bristle brush in a drill and compressed air to clean out the female ends of the hub, and a wire wheel on the lug bolts.
Lube won't cause a lugnut to work loose. It's about clamping force. Lubed threads will yield a higher clamping force for a given torque. Typically 25-35% higher, which may be enough to deform a stud.Unless specified otherwise, torque specifications are based on dry threads.
toughest/tightest lug nuts I ever removed were on my old C230k, I was jumping on the damn breaker bar, car was rocking, it was crazy.
They are a pain but you should have the little threaded dowel that allows you to screw it into the top one to hold the wheel in place.
I put a little bit on and am more worried about putting it where the hub/wheel meet so the rims doesn't get stuck on it.
That's where I put it. It's really annoying to have to use a torch to take off wheels.
Good idea?
On the side of the road just let your jack down a touch till it pops off.....maybe (is that a terrible idea, seems so)
Token swipe. More concerned about the rotor face and hat seizing so they get coated.
I rarely put anti-seize on lugs, but I have broken more than a few thanks to heavy rust build up.
Don't put that **** on there. Makes a total mess any time you have wheels off. I've pulled 10's of thousands of lug nuts and never had one seized.
Ever break a stud? I have and it sucked.
I’ve removed tens of thousands lug nuts. Only ones that ever broke were because the last jack wagon who put them on cross threaded them and sent it. Anti seize just makes a gigantic unnecessary mess. No anti seize, hand torqued, no problems.
The only time these things won't work to anti seize is on the exhaust hardware... now that is something else.
