Anti-seize opinions.
Tunar
Woodstock VA
When I started wrenching on FJ40's many years ago, I learned to use anti-seize on just about everything (automotive that is). Just a little extra insurance that parts would come off easy in the future. I'm guessing it's graphite suspended in a oil therefore lubricating and preventing components from rusting where they meet.
The only place I've seen a downside is in the lugnuts on my truck. The anti-seize has kind of become a thick paste that almost takes more effort to overcome. I'm guessing that's from attracting dirt and a thourgh cleaning would correct that.
My brother recently had to take some training on torque techniques and learned that no modifiers should be applied to the wheel studs or hub. I know critical engine components should be torqued dry except fasteners with factory specified additives. I'll acknowledge that lugnuts would fall under critical fasteners. I was just wondering what opinions or knowledge is on GJ in reference to anti-seize.
Jay H 237
Torrington, CT
I do put a little bit on the lugs, but I'm also in a rust belt area. I do other fastners sometimes too.
I think for most of us it comes down to personal preference and the location where we live.
nadogail
Coronado, CA
The answer is "It Depends".
Manifold studs need anti-sieze on the brass nuts securing exhaust pipe flanges to the manifold.
Anti-Seize works great on many marine applications.
It also gets allover your tools and hands.
sberry
Brethren, Michigan
A little, sparingly. Whoever came up with dry torque needs an examination. Snap-on torque wrench manual of old says,, all values for clean lightly lubed threads, about like modern penetrating oil which is what we put on nearly everything threaded and lots of 8nterferance parts we want 5o come apart.
NUTTSGT
Northern Central Ohio
That's why it makes a great anti-theft device too. Anybody that has used it, knows how it makes a mess and they will avoid touching anything with anti-seize on it.
exmaxima1
Midwest
I put it on the wheel studs and the faces of the hubs/rotors so they come back off easily.
+1
Without Never-Sieze I typically need my dead blow sledge to release the wheels on my BMW. I would hate to be in a situation on the road where I couldn't change a flat.
plinker
Northern Wi
Any flange type surface that will rust together and around the center hole on rotors always gets anti-siezed so it will actually come apart again. Sleeved bushing bolts such as shock bolts & control arm bolts also get a coating on the shoulder of the bolt.
I find the copper better then the regular, Nickle better yet, both are more expensive.
unslow1
Illinois
This sums up anti seize from my experience 040a97f1b16045f90e498a9e10474d9d.jpg
Sent from my SM-N960U using Tapatalk
One of the guys at work today asked a girl to hand him the anti-seize. I told her to be careful with that or she would end up looking like the tin man. She had no clue what I was talking about.
unslow1
Illinois
+1
Without anti-seize I have to use a torch on every wheel of my Toyota.
unslow1
Illinois
Use a lady slipper pry bar between rim and hub for stuck Toyota rims (Alloy ones). Ones that wouldn't come off with heat and a sledge hammer come right off. It amazed me when I finally figured that out.
I'll keep that in mind but mine are steel. I've been curious if Fluid Film would work.
Legion Prime
Leelenau County MI
That depends on what's speced for the fastener. Some are speced to go on hard and dry while some are speced to go on with oil, assembly lube etc. Some manufacturers have gone to hybrid torque specs ie torque to say 80ft/lbs and then turn another 120 degrees. It's not as accurate as using a micrometer to measure fastener stretch but it's not as labor intensive and time consuming either. By using a lower torque spec and then degrees of rotation there is less variance from clean vs dirty vs lubed vs dry threads.
Me personally I'd use it for jackin if it weren't so thick. If I'm putting together something with threads and it doesn't spec loctite it's getting antisieze period end of story. I've worked on so many cars with a combination of rust, dirt, corrosion, ugga dugga torque specs etc that I just put it on EVERYTHING, it really does make a difference down the road when you need to take something apart again be it lug nuts or tie rods. Even if it does get caked a bit a wipe with an oily rag (there's one somewhere in your shop right?) usually cleans that right up.
Tonyuk
Scotland
Use common sense.
The torque values are for clean and new fasteners, so over time, with a bit of wear and corrosion, its going to change no matter what.
VAG spec optimol paste to the threaded portion of their wheel bolts, its essentially a ceramic based antiseize.
Porsche spec the same stuff to the threads on their centrelock wheel nut.
I've always used a small amount of it, and never had an issue. If anything the reduced friction should increase the stretch of the bolt, and therefore the clamping force, when it reaches the specced torque. Wheel bolts have a large margin when it comes to overtorquing before they get damaged so i wouldn't worry.
PCMusicGuy
Houston, TX
I've never used any antisieze on wheels or brakes or anything before and have never had any issues removing lugs or bolts. I guess South Louisiana and Texas doesn't really have weather where it makes a difference?
NUTTSGT
If you lived in the rust belt where they use salt or brine, you'd see the difference.
lilredex
Toronto
Same here, otherwise hammer action will be necessary. One place I do no use it is on auto brake adjusters, it cakes up and seizes the auto action.....brake grease here.
Jlbc212
Northeast MA
Living in the rust belt I use it generously. There are a few exceptions where I don't use it. I've never had an issue because I did use it, except for getting it off my clothes. Where others have commented about "caking", like on lug nuts or brake adjusters, it's never failed for what it is intended to do which is to prevent metal parts from seizing together.
SGKent
Citrus Heights CA
... except for getting it off my clothes.
that is why it is referred to as that silver (or copper) stuff that gets all over everything if you look at it.
Oh - I see that has already been addressed several times...
T
Tunar
Woodstock VA
Great info, thank you. It's always been helpful in removing fasteners at a later date with no negative issues so I'll continue to use it. We use plenty of salt here in VA in the winter. Most of my automotive education has just been from other car guys so I'd figure I'd ask. Thank you.
sberry
Brethren, Michigan
I use more spray cans of pen oil installing than removing. It has about ended our seizure issues, its fast and simple and quite clean. We spray rotor hubs, wheel hubs, spring shackle bolts thru sleeves and almost all nuts bolts we install and its about the perfect juice for lug nuts, just to keep them from dry seizure and it repels the first wave of water.
ransil
pa
I put that **** on everything
Sent from my SM-G920V using Tapatalk
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
This answer is restricted to MB engines from the sixties.
4 and 6 cyl, cast iron block, aluminium head and lots of different metals in the cooling circuit.
The exhaust( and intake) manifold sat on M10 and M8 studs in the aluminium head.
The manifold nuts were heavily copperplated. I have removed many manifolds that had not been removed until I did so after 20-30 years. The nuts came off with no problems and the studs stayed in the cylinder head.
Another not so happy situation was to replace the thermostat that sat in an aluminium external casting. The cover was secured with 4 off M6* 30 mm galvanized screws. After having broken a number that were hopelessly seized I learned to drill them out before even trying to screw out. Cleaned up the thread and used teflon tape over the threads when putting back. The teflon taped screws came out easy even after many years.
Ola
QwikKotaTx
Seabrook, TX
I dunno. I am only a half mile or so from the water and I've seen plenty of things that anti-seize would have helped on. As long as you use it sparingly and take into account the torque change any issues are being blown out of proportion. A 120 ft-lb lug nut is not going to magically come loose just by adding a little lubricant.
RKA
Having a fastener come loose because it's been lubricated is a bit of a misconception (as long as the seat of the fastener is clean). It's over torquing the fastener that becomes a problem down the road. If you use a fastener within it's designed torque range, it can be reused many times. If you exceed that, you'll find the threads stretched to the point where it will hold the first time, but each subsequent use it won't properly hold when torqued to spec and it will back out on it's own. Many suspension/drivetrain/engine fasteners are designed to be used in this way and are specified as one time use for this reason. If your lugnuts ever reach that point, replace them. The lubrication on the threads causes you to stretch that bolt more to reach the desired torque spec. In many cases it's fine, but if you later find the bolts or nuts backing out, it's not because of the antiseize in the threads, it's because you stretched them too far.
And if you ever encounter a situation where you need to put a 3-4 ft lever on a breaker bar or wrench to remove a lug nut/bolt installed by a shop, at a minimum, mark that bolt and check the torque every week for a few weeks to make sure it's not backing out. Or better still, just replace it. The nuts/bolts are usually softer than the hub flange or studs, so *usually* you'll be in good shape just replacing the lug nuts/bolts. But keep an eye on those new bolts just in case the flange or stud was damaged too.
FakeNewsRealHP
Midwest
Many mfg make a spray can of anti seize now, it is much less of a mess besides overspray! I commonly use LONG stainless hardware with a nylon lock nut to fasten a part at work, without anti seize the two gall up instantly before it gets tight and you have to break the fastener.
Falcon67
Merkel, TX
I use what the mfg says on engine fasteners. Everything I use in critical areas on the race cars comes from ARP and has specific torque specs when using their lube and usually with engine oil. Wheel studs usually get a shot of WD-40 and torque to spec. 80 ft/lbs on 1/2" studs, 100 ft/lbs on 5/8". The only anti-sieze I use is on things going into aluminum heads and manifolds. Spark plugs, bolts, etc. And on stainless anything into aluminum anything.
zmotorsports
Northern Utah
The technical answer is that anything that is put onto the bolts and nuts changes the amount of bolt tension produced by a given torque applied to the nut. So, the torque value isn't valid if anti-sieze is applied and changes the force.
In the real world, you need the anti-sieze for anything to be taken apart again that is subject to corrosion. So, it's a necessary evil, and the fact that it changes the torque probably is of lesser concern than the corrosion is.
In general, I think anti-sieze lowers the force needed to torque a bolt to a specific tension. So, you end up overtightening the bolt.
^^Agreed.
I uses Permatex's Anti-seize on most all suspension fasteners up to an including wheel studs but a little goes a long ways. I cringe when I watch people slather that stuff on fasteners and then when they run them down with an impact to snug the stuff gets thrown everywhere. I use the brush to lightly coat the threads on the studs then torque properly knowing that they will end up being very slightly over torqued but they will at least all be uniform. Many times I back off a few lb/ft but generally to spec.
I also insist on using it on all suspension components especially those with steel sleeves which not only aids in removal but also prolongs the life of the components.
Another product that I use in similar situations on suspension components is Fluid Film for many of the same reasons.
QwikKotaTx
Seabrook, TX
I hear what you are saying but I highly doubt 130 ft-lbs and anti-seize is going to yield a wheel lug. And if it does need to be replaced how are you going to replace it? Most people pull them in with a washer and lug nut which I guarantee you requires more than 130 ft-lbs to seat. That is most likely the worst case for the lug stud, bringing you back to square one.
Anti-seize increases the torque about 10 to 15%. Reduce torque wrench setting accordingly. Not that anyone uses them...
RKA
I'm not saying it will or won't, just adding a little clarity on the issue of nuts backing out and why they might. It's fine if it doesn't cause an issue, but at least know the signs that it did cause an issue so you can address it.
Lucky13driver
Corpus Christi Texas
I use Permatex on any thing that doesn't have to do with an engine. I have had it go dry and firm up. A quick hit with a torch and the nuts and bolts come apart easily.
Fix Until Broke
SE Wisconsin
Do you have any links to spray anti-seize?
I've been using this for years as "spray anti-seize" - Krylon 1402 High Heat Aluminum specifically. Nice and thin so it does not gum up threads and such, dries fast, not messy like most pastes, everything comes off without issue after a few years in the salt, you can weld right through it, use it on exhaust, etc. It can be a bit hard to find, but works well and inexpensive.
images
Be careful with your 10-15% assumption - friction is the largest component of the torque you apply to a fastener. A 5% change in friction can change the tension in the fastener by 50%. On a lug nut, that may not be too big of a deal, but other applications it is the difference between success and someone's life. As Legion Prime mentioned earlier, a low assembly torque and then an angle is the best method for any remotely critical fasteners in my opinion. This procedure reduces variation a LOT, is relatively easy to execute and very robust. A torque wrench is likely one of the most inconsistent methods of insuring a properly installed fastener - it inspires confidence in inexperienced hands.
