Anti-seize.
bluedog225
Texas
Is there a chart that specifies different anti seize for different metal combinations? Similar to the chart that lists the chemical resistance of various types of glove material. Anti-seize for stainless-aluminum; copper-stainless; aluminum-copper, zinc coated-copper, etc.
I see permatex makes a variety but they don’t seem geared to different metal combinations. Or is it all the same magic.
seems a little haphazard.
Thanks
Steve_P
I've used the nickel type for decades as it has the highest temp rating. I worked at an auto glass factory, and we used the same stuff on all of the fasteners, which were stainless steel and were used in 1100F ovens. For sure it's not going to work 100% of the time, but it's the best you're going to do.
goldtang
Western Australia
Thanks. That’s helpful. This is the kind of thing I was wondering/worrying about. Seems like the chemistry for different metal combinations would be entirely different.
Can you tell us what you are fastening
if you are doing dissimilar metals have a look at Tef-Gel or Duralac
bluedog225
Texas
I’ve got some aluminum and stainless stuff right now. May also tap some copper bars for stainless. But it was more of a general resource question about whether there was a table or chart that I could keep handy.
Bondo
Greenfield, Maine
Ayuh,...... I used to use never- seize on everything,
n more times than not, it came apart tough, with little to no sign of the never-seize on the parts,.....
Over my many years if posting over at iboats.com, I became close friends with DonS, the guru of I/O repairs, who unfortunately passed some years ago,....
Anyways, over those years DonS called never-seize, Always seized,...
DonS lived in Alaska, working on I/Os that literally lived in saltwater,....
After all the brow beatings, 'n a few phone calls, he convinced me to not use never-seize, 'n try his "Go to" cure for seized nuts, 'n bolts, which also stops ssteel from galling,...
'n that is Quicksilver Perfect Seal,......
Which is exactly the same as Form-a-gasket non-hardening liquid #3,.....
Since then, I put #3 on every bolt/ nut I put together,.... Never had a seized/ rusted/ galled nut or bolt since,....
U-bolts, lug nuts, motor parts, I/O parts, Everything,.....
CJM8515
i always used the nickel based one, never ever had an issue. i wont put it on engine bolts or lug nuts/studs tho b/c it changes torque value and i rather not have those items come apart lol
jubilee
Colorado
Tip for for silver anti seize, Teflon pipe dope, and etc.
To thin dried up containers, add virgin olive oil.
Figured it out 40+ years ago by reading MSDS sheets.
Works and won’t dry up.
PCustoms
VT
I'll bite.
What in the SDS makes you think these have an olive oil base?
RoninB4
Under My House
-Just an FYI for some. If you're out of anti-seize and you need something, Milk-Of-Magnesia can be an ersatz substitute. Cheap and readily available at about any convenience store. It imparts a thin film of magnesium to act as an anti-seize. It doesn't stand up to hot temperatures as well either but it does work. We used it on airplanes in the Air Force back in the day and I've used it on industrial applications.
Jeepster04
Dang, I sure hate to hear that. I use to frequent the iboats forum, maybe 15-16 years ago, and remember reading his posts. Dude sure knew his stuff.
Is this what you're talking about? The only issue I see is the low temp rating.
Ive been using loctite marine antisieze for awhile, but Im no where near saltwater. Its metal free and good to 2400F. I bought a 5lb can of it, so I think Im set for life.
zimman
Mark Twain National Forest
If you're not careful using Anti Seize six months from now it will show up in the crack of your ***. LMAO
Zim
Edit. We used to put a small dab on the trigger of our boss's impact gun. He'd have anti seize all over him in minutes. He was pissed.
bluedog225
Texas
I think graphite is not great on my stainless/aluminum applications.
Bondo
Greenfield, Maine
Ayuh,.... That's the stuff,.... As DonS explained it, due to the tenacity of the stuff, air can get 'tween the bits, so corrosion can't happed,....
