We just went through this discussion last week. That said, when working on a modern engine and installing OE plugs, I don't use it. Most modern plugs are coated with a nickel plating, which should keep the plug from getting stuck in the head. Antiseize also works as an insulator, and can change the heat range of the plug as well as "baking" into place (what he may have been referring to).
There are reasons to use it, but I feel that the negatives greatly outweigh the positives in a modern engine.
I would never use it on new spark plugs. Many manf. recommend against it specifically and the new plugs have a special coating that requires no anti-seize. If the plugs are coming out and going back in and you live in the NE then maybe a tiny bit might be appropriate. Like everything else, it is necessary to read.
Edit: What stick said.
The Ford mod/Triton engines almost always have plugs seized in the head, so much so many independent shops won't touch a plug change on them. Rare to get them all out without breaking one.
jack vines
OK, how about the spark plug manufacturers themselves? They all agree:
This may be a novel concept but, I refer to the service information for the vehicle I'm working on for guidance. If the service information says to use it, a little dab of nickel based antiseize goes on. If not, it goes in dry. Spark plugs aren't the no brainer they once were.
You are a student and your instructor preached to you not to use it on spark plugs, but you know better? That makes a lot of sense.
I say go with what the manufacturer recommends. It takes a long time for conventional "wisdom" to change I see, even when a poster goes to the trouble of presenting hard data right from the horse's (plug mafg's) mouth.
Anyone who is saying ALWAYS or NEVER use anti-seize, without considering the application, is wrong.
Anyone who tells you not to use it never spent 3-6 hours getting the plug base out or pulling a head because the numbnuts that put the last set in put them in dry.
Also, how can you be so sure that a lack of anti-seize is the reason the plugs are hard to get out? Maybe by lubing them with anti-sieze you keep over-torquing the plugs and distort the threads? Maybe they have carbon buildup? Maybe some numbnuts cross-threaded them?
Would WHT like Elroy to explain again, why making the generic claim that never-seize raises the heat range is BS
Yes I have and still don't use antisieze in a lot of applications, depending on manufacturer recommendation. Mr Holeshot, you make a lot of assumptions and are very quick to de-value other poster's opinions. You're hardly the first guy in the world screwed by a spark plug.
Perhaps if your removal and installation techniques were improved the use of anti-sieze might be less of an issue?
Plug makers can tell you whatever they want, That doesn't make is so.There are brake pad makers that tell you their pads don't squeal, Tire builders that tell you their brand rides better, wiper blade makers that tell you their wipers don't streak, rotor makes that tell you their rotors don't warp.
Making optimistic claims to sell your product is a very different thing than a manufacturer (or several of them...) giving bad installation instructions. That would only make their product(s) look worse.
You are welcome to feel so assured in your opinion but I will take hard data over anecdotal evidence anytime.
Also, why de-value anyone's opinion at all? If you make a good point and make it well, you don't need to.
If you want to know if you should use anti-seize take the time to talk to one of the engineers like I did.
http://www.garagejournal.com/forum/showpost.php?p=1358788&postcount=32
ok, enough with all the bickering. The cold hard facts are this:
Spark plug makers may say not to use anti-seize. In the real world and with real experience, using the proper amount of anti-seize will NOT harm anything.
Putting spark plugs in without anti-seize may come out fine in the future, but DO have a higher chance of getting seized.
Most good mechanics will put anti-seize on spark plugs. This is what one should do to avoid potential problems in the future.
A thin layer will have no negative effects and is beneficial. If you cake the stuff all over the plug, then yes, you may have problems, and maybe that's what plug makers are trying to avoid.
But as mrholeshot pointed out, I would rather do what so many mechanics with real world experience do every day with no problems, than to follow some company's instructions that may quite possibly be motivated by other factors than to stop plugs from seizing.
That's pretty funny calling what you posted "cold hard facts." You obviously have no clue what a "fact" is. Most everything you posted is opinion (or purported facts without evidence) and opinion that many disagree with. It is also opinion that should be devalued because it is mostly not based on facts. The two mechanics that on this board that have shown themselves through their posts (Stick and Fedwrench) to be the most knowledgeable have both said the same thing:
Follow directions, and directions many times state not to use the stuff. If the service manual says to use it, use it. If not, don't use it. It has known drawbacks that have been pointed out many times here. Manufacturers know way more about their product than you do and are not in the business of telling you to do something that will damage your car; that is just nonsense coming from conspiracy theorists.
How anyone with a remotely open mind could read the posts and come to the conclusion that anti-seize is always a good idea is just not very smart, quite frankly.
Never had a problem with a start-up misfire on any 4.6 due to antiseize. I'll take that one with a grain of salt. I've seen it caused by lack of using dielectric grease on the COP and allowing moisture in. Removing the COP and putting it back on could have cleared that problem up (for a while). My shop did the work for several of our local mustang clubs and 90% of those cars have Modular Engines. They are quite sensitive. We have had them set codes after installing underdrive pulleys. Never over anti-seize and we used it in every one that got plugs.
I won't say it it didn't happen, just very doubtful that was the actual cause. But I've been wrong before.
First thing I checked after scoping the coils and finding high firing voltages was to pull the boots and check for dielectric, and there was a nice light coat on the inside of all the boots. Car had the new plugs installed at most two weeks before it came back and apparently ran fine when it left. Secondary ignition looked perfect after cleaning the antiseize out of the holes and installing new plugs, so I doubt it was coils or boots. Like I said, the previous tech used a bit more antiseize than I would have if they had been uncoated plugs, though nowhere near excessive. Probably put plug resistance just out of spec enough to create problems.
I'm just one of those neanderthal heavy diesel guys, so my knowledge of modern electronic ignitions is somewhat limited, but I still don't see how anti-seize can possibly affect the heat range of the plug. Altering the resistance between the head and the plug, sure, but not heat range. To be honest, I have a hard time wrapping my brain around how a couple of ohms can make a difference in the grounding of the plug too, but what do I know?
Resistance goes up, heat goes up, heat increases resistance, repeat and so on. Tolerances are so tight now that some stuff that used to be pretty minor can have effects on today's systems. In my case the misfire was bad enough to throw a code on startup, but under normal operation it appeared to work fine.I'm just one of those neanderthal heavy diesel guys, so my knowledge of modern electronic ignitions is somewhat limited, but I still don't see how anti-seize can possibly affect the heat range of the plug. Altering the resistance between the head and the plug, sure, but not heat range. To be honest, I have a hard time wrapping my brain around how a couple of ohms can make a difference in the grounding of the plug too, but what do I know?
Every mechanic you have used, lol. How many is that? I could walk into the local Chevy dealership and line up 10 mechanics that say to never use it because it screws up the heat range of the plug and can cause electrical problems. I could walk into the Mercedes dealership and no one would tell me to use anti-seize because Mercedes doesn't recommend it.
You and I obviously value different sources of information. I prefer manufacturer instructions and you think you know more than the manufacturer. I'm not that vain. You prefer the word of mechanics you have talked to and you think they know more than the maker of the car and plugs. So be it but don't start talking about how these mechanics you have talked to are some singers of spark plug gospel, because they are not.
