Anvil stand completed...
burgie
Falcon, Colorado
A couple weeks ago I got my anvil all cleaned up and this past weekend I built the stand for it...
Some commercial place had an ad for free pallets, so I went and got a trailer load. I used the 2x6s for bridging between the studs in my shop and the 4x4s have been sitting in a stack for 2 years. I knew I’d use then for just this purpose. The anvil is held in place by used railroad spikes and the hammer holders are the old U-bolts from my F-350 PSD 4x4 when I added helper springs on the front end 22 years ago (yes I saved them that long)...
Here are a few beginning pics...
burgie
Falcon, Colorado
Here are some finished pics after charring the wood with my Mapp gas torch and a couple coats of boiled Linseed oil...
1982fxr
Phoenix
I've never used blo. Did you do anything special to get good absorption on the end cuts?
I ask because I did some polyurethane coating recently and the end cuts didn't want to soak in very well. Might be a moot question if blo is a lot thinner than poly?
Looks awesome.
burgie
Falcon, Colorado
1982fxr...thanks man. Nope...just applied 2 coats to the entire piece and nothing else. The end cuts on the top took the linseed oil very well...
ColumbianRon
Franklin, TN
Now that is cool. I especially like the charred look. I was planning on doing the same thing with 4 x 4s, then I decided to use a large stump and cut it down to a height of 26," which is what I need with the height of my anvil. Seeing how well yours turned out, I may rethink my decision to use the stump.
Tractorsellr
Tx
You knocked that out of the park. That is a really nice job. My anvils just sit on old tree stumps.
HotWire
Montana
Awesome work! I live the look and reclaimed materials. I will be copying this design. Thank you.
orangeblood
Texas
Looks awesome.
BLO can be thinned with turpentine to improve penetration. i have used ratios up to 50/50. you can get the ultimate build up you want thru multiple coats or reducing the percentage of turpentine. for a hand rubbed finish add poly to the turpentine/BLO mix
lots of good youtubes on homemade finishes using BLO.
OP: very awesome work! love the use of re-purposed materials and the burned / BLO finish
burgie
Falcon, Colorado
Very nice. Do you sledge hammer brackets on both sides?
I decided to place the hammer holders on one side only. This was largely de to the fact that, as I understand it, being right handed I want to stand such that the horn it to my right side.
Also, while I have years (decades) of construction and woodworking experience I am new to metalworking so I will be on the learning curve. Anvil...done. Next project that will be started soon is a propane forge...
Thanks for all the nice compliments!!!
