Any other gearless bit ratchet available?
Grokew
Home
The only one I know of so far is the RR40S-BH1/4 from omegatec. It looks a bit bulky, but I have no experience with it. If anyone here has some experience with it, could you describe it's advantages and disadvantages?
Are there any other gearless bit ratchets out there?
JradM
Alberta
I don't know of any gearless bit ratchets. The one you posted was news to me. Does it NEED to be gearless?
I do like bit ratchets generally. My two favorites are the Wurth/Zebra and the Titan micro swivel.
The Wurth is extremely small - doesn't add any height to the bit (it pokes through the middle slightly and you remove a bit by pushing it back out). 72 teeth, so pretty fine action, but I've put considerable strain on it without issue. I love this little guy.
The Titan is a little different. I'm sure the novelty is part of why I like it. 90-teeth for even finer action - however it is taller than the Wurth. With a roto head on it, it can flex to access different angles or be used like a screwdriver. It comes in two flavors: chrome vanadium or aluminum handled. The aluminum version is sold in several different colors.
Bubba Fett
Eastern NC
I have the 1/4 socket driver version of the Titan ratchet. I like it. It's TINY though. That means not much torque, and it's easy to lose, but it can get in tight places.
G
Grokew
Home
I have a prestaratchet that is almost identical to the Würth but with a 52 teeth mechanism. It's my favorite so far. The reasons for the gearless bitratchet is to reduce Back-drag and reengagement angle. It is not strictly necessary, but it would be interesting to find more models,. especially a thinner one.
Edit:
Please forgive my mistake, I'm not used to the interface and replied to you, instead of JradM. I would like to get a set of titan swivel mini ratchets. I have the offset micro bit and 1/4 ratchets. They are great, but the chrome is So smooth that it gets slippery sometimes.
G
Grokew
Home
Nice, that's really interesting. I bet I can use a strong magnet to hold the bit instead of the large rubber cap.
Edit: oof, didn't pay attention to what you wrote. It isn't hex. Still interesting
kbeefy
Harington, Eastern Washington
I have a Lisle 62450, which will drive a round shaft without a gear. I've never tried a hex bit in it, but imagine it won't work
I have that same driver. A hex version would be awesome! I was just looking at mine the other day trying to find the perfect way to use it with a torx.
I have used it successfully on a few screwdrivers with the correct sized shank....
G
Grokew
Home
3 days ago I got the titan mini swivel 1/4 drive ratchet (not the bit ratchet). Quite a nice lil thing.
