I have recently bought myself an older above ground 2 post hoist via CL;
the hoist is still apart from when I took it down from where I bought it, and I have a source to get some of the "more easily handled" parts, powdercoated.
there are a couple parts we are debating on just spray painting, (the motor itself, will definitely be rattle canned, not powdercoated) but like the hyd. cylinders; one was known to be leaking when I bought the lift; I have rebuild kits on hand, and both will be treated to a rebuild before I install them; and, the oil reservoir from the pump assembly is made of metal and can be removed pretty readily from the pump;
what are your thoughts, on whether these oughtta just get scuffed and rattle canned--or, if they can be safely be bead blasted and powdercoated? and at what stage?
By that, I mean/ do I rebuild the cylinders and then mask, bead blast and coat? OR do I blast and powdercoat THEN rebuild, OR take apart, and do the pieces (cylinder and gland nut) and then assemble? --or, is this something I should just figure an extra couple cans of Krylon for, to be safe?
I do know that powdercoat would be more durable, and that I definitely plan on having this hoist for a LONG time; but I also know that new cylinders are $935/each (the lift has 2 of them); that, I am NOT doing.
