Any spark plug sockets that don't ****?
Ron_J
Central PA
Many moons ago I bought a "good" plug socket. I got tired of the rubber grommet coming out of the socket and sticking on the plug, so I started just using a rubber hose.
I had to pick up a couple things at harbor freight over the weekend and as I walked by the sockets, I saw the plug sockets. Not sure why, but I picked one up. Well, after about the 4th plug, the grommet started sticking to the plug. I had to add a little grease to it almost every time.
I know HF isn't exactly known for their high end tools, but I had the same experience with one that was supposed to be better.
Anyone had any luck with these sockets? I'm about to go back to the rubber hose trick.
jgromada
Maryland (between DC & Balt)
I am not a fan of any of the Spark Plug sockets with the rubber grommet. At some point the rubber will wear out.
I ended up getting a magnetic socket. https://www.amazon.com/gp/product/B01MSPBKG5/?tag=atomicindus08-20 Just a suggestion.
BlakeTheCarGuy
Roanoke Virginia
I use my old Craftsman USA ones mostly and haven’t ever had the boot come out. I have many spark plug sockets between work and home and the Craftsman are my favorite I also have a Kobalt set that is really nice and has worked fine. I have some no name ones that the boot always comes out of so what I do is take the boot out put super glue on the bottoms and press it back down in there it has worked good too since then.
jgromada
I bought a Gearwrench magnetic socket with built in swivel extension. Works great for OHC engines with deep spark plug wells.
I had considered those but decided not since i had a bad Gearwrench experience recently. I really didn't like the idea of a built in swivel extension. I worked on someone's Saturn V-6 recently and the added length would have been a show stopper.
I really like the idea of Locking extensions. I have had issues in the past where spark plug socket gets stuck on the plug & the locking extensions eliminate that problem.
stonesfan68
Houston, TX
The Gearwrench magnetic spark plug sockets work well and the built-in extension is useful in many cases, but not always. There are several brands that offer a magnetic socket, or you can look at the major tool brands like Snap-on, SK, Mac, Matco.
Chevy-SS
Rhode Island
Magnetic ones work good. For the rubber ones, I have epoxied the rubber into the socket and that holds it. And I have some where the rubber has fallen out and I just leave it out. I guess it all depends on the situation as to which one I use.
I've been wrenching on engines for ~50 years and still don't have a plug socket with the flex, but that does look nice. A flex is rarely needed, but I can see some cases where it might be handy. It looks like it might be prone to breaking plugs (cracking the ceramic) though if you're not careful.
I do like the rubber hose trick for starting the plugs into the holes. This helps prevent cross-threading.
cmandp
New Jersey
I only bought the one socket but quality is good and the magnet works perfectly. Funny I bought it to work on my wife's L300 with the 3.0L V6. Not sure about the Vue or other Saturns that may have less room between the back 3 plugs and the firewall.
I have locking extensions too and yes for regular spark plug sockets they really save a lot of frustration if the socket gets stuck to the plug. That's the other nice thing about magnetic sockets and ones with a built in extension; the extension is locked to the socket.
Two Speed
Ontario Canada
They are available with various extension lengths. Buy the one that suits your needs. A few different brands to choose from as well if gearwrench leaves you sour.
I bought two. One with built in extension for my ford (works great) and just a socket for my chevy's where an extension would also be a show stopper. Won't be going back to rubber.
Alex.
pbon
I can’t use built in extension since the 6th plug is under the cowl on my inline 6 BMWs. I’d rather add my own extension so I can choose the length when space limits change.
Jagmandave
Overland Park, Ks.
I always use one of those extensions with the ball end when changing plugs, using a straight extension I have frequently broken plugs, with the ball it allows enough flex that when it breaks loose I don't break the plug.
OTOH, I just about can't think of a time any more where if I'm taking them out I'm not replacing them....so if I do break one it's not really an issue.
qqzj
The swivel feature is very useful typically. If the length is a problem, you can find on Amazon some magnetic ones with a super short swivel extension
Sent from my Pixel 3 XL using The Garage Journal mobile app
unslow1
Illinois
I have the Gearwrench ones and they work fine but the extension is not always wanted. I also have a few from the tool trucks but the ones I usually used are from Autozone. They are the magnetic without the attached extension.
visionguru
Chicago
Gearwrench
The swivel extension helps A LOT when there are lots obstructions, such as the rear bank of a V6 engine.
Wakefield
Arlington VA (but would like to get out to country
Koken is where it's at. Magnetic is infinitely better than the stupid rubber grommets. I have a few generic magnetic ones and the gearwrench set with the built in extensions, all work well.
Does KoKen have a double jointed one ?
Snap On double jointed one,"don't leave home without it" ? when Craftsman just wouldn't do
Mr_B
Reading
koken and astro do great design plug sockets .
few other gems but lot of the magnetic ones are junk and a quality rubber one actually better at avoiding issues .
M6erfan
'Merica!
+1 on the Ko-ken SP sockets. They're all I use anymore. I gave my GW spark plug set away and never looked back.
Ign
Butte Peak ND
Yep, even though I was just bashing GW in another thread I was also going to recommend this. It's virtually required on the '09-ish+ Rams and I just used it on a '99 XJ. Even though swivel really wasn't required for the XJ it was still more help than hindrance for the job
Negen
Seatltle WA
I also use the koken spark plug sockets. I use the zeal magnet ones but no built in swivel. If I read the catalog correctly they seem to make one magnetic sparkplug socket with built in swivel.
14 mm 3345p swivel socket with magnet
3305pz 14mm, 16mm zeal socket with magnet
3305p 14mm,16mm socket with magnet
3305-250mm,14mm extension with magnet
Sent from my ONEPLUS A6013 using The Garage Journal mobile app
DerekV
Central TX
+1
I’ve also had excellent luck with my USA Craftsman’s. I have, however, used other ones that’ve had the rubber pop out. The ol Craftsman’s just keep working like they should. They’re great with locking extensions.
bubinga
I like my Gearwrench set.
It has a magnet to hold the plug in the socket.
They are swivel sockets, with an extension built on to them.
that's the same set I have, it came with 2 sockets, and a flex head ratchet.
BlakeTheCarGuy
Roanoke Virginia
+1
I agree totally
richfinn
Leeds, Yorkshire, England
https://www.uktools.com/16mm-38drive-70mm-long-spark-splug-socket-with-spring-clip.html
If you look carefully at the Ko-Ken design, the spring clip actually holds the metal hex part of the spark plug and a brass insert supports and protects the insulated portion
This avoids the rubber insert wearing out and avoids the magnet attracting debris which could potentially crack the insulator!!!
I have a really old one in my truck, works great
Negen
Seatltle WA
I have these too and work good too. Work nice on marine motors that have tighter spaces.
Fedwrench
Valley of the sun
I think Gearwrench with the built in extensions, the OEM Tools magnetic, and KOKEN are outstanding. The more knurling the better :lol: I also like JTC Tools' plug sockets.
I hate the Snap on kind with the taper lock design. When I want the socket to release it doesn't, and when I want the socket to hold, the plug falls to the floor :wtf:
Qualitytools
SOCAL
+++++1 for Koken. Check out their selection with magnets as well as clips. Koken and you will not regret it.
Lassen Forge
I knocked the gearwrench mag sockets until I tried them.
They really DID come up with a great idea... that works.
YMMV, Kokens are great, S/O's rock, Even the flying V Craftsmans with the dreaded foamy inserts work, but you need to find what YOU like. Each have their plusses and minuses... I like my Gearwrench ones, but that just means that's just what I like.
lethal-6
Lascassas, Tennessee
I would also recommend the gearwrench set. Otherwise look at the other options snap on, vim and others. The magnetic ones are great for the deep ones.
