Anybody else into Harrold Tools?
I guess that by 1939 Sears had decided that purchasing tools from Germany might not be such a great idea so at some point they switched to Danielson. I wonder if they ever used Harrold as a supplier?IMG_9002.jpeg
1939 dated Danielson supplied Dunlap adjustable wrench.IMG_2988.jpegIMG_2989.jpegIMG_2990.jpeg
Here is a more colorful and biographical tilt on the early history of Harrold to the trade mag establishment notice I posted upthread, with a partial photo.
I don't do Facebook, but here is the link for someone who does who might be able to see more of the post...
I also ran into this 1922 oddity, that I couldn't readily explain and have not taken the time to explore further yet...
And here is a 1924 patent. (1510593, for the Search engine)
^ I am somewhat puzzled by what I found when searching "Colonial Tool & Forge":
1922 announcement regarding name change of Harrold Tool & Forge Co. to Colonial Tool & Forge Co.
puzzlingly, the 1922 Ohio Industrial Directory shows them as being two separate entities at two separate locations.
While in the depths of this rabbit hole, I found one gentleman who is apparently very serious about his Harrold:
Harrold collection of Joshua Laclair
More discussion regarding Harrold at BladeForums.com
LesserSon
PA USA
Sears…
The answer is yes, but I’m not sure about regular tools. The pliers, and maybe the screwdrivers (possibly all the tools, though I think it doubtful) in the HappiTime tool kits marketed for boys are clearly Harrold slipjoints, and Harrold was credited (I think on Progress is fine) with supplying boys kits through other retail outlets.
Mintgrun
Kingston, Wa.
I've got a couple of Shok-pruf screwdrivers. I didn't realize there was a Harrold connection. I think someone reshaped the blade end of the smaller handle.
:D
So maybe we can get Lugz to stop completely ignoring this mfr.
:ROFLMAO:
Which you've apparently been holding out on us until now! :) Very cool!
Looks like this guy from the 'screwstarter/holder' thread also has one that apparently also has a screwstarting/holding provision.?
EBONITE SHOK-PRUF 9" Flat Head Plastic Handle?
^ I thought we had previously ascertained that the "Forged Steel USA" inside the triangle was Harrold? :headscrat
I found this pair of slip joint pliers with the Forged Steel USA in a triangle. No other maker marks. Is this a Harrold's?
LesserSon
PA USA
I think yes to both, but given that “Forged Steel USA” doesn’t actually spell “Harrold,” and that there have been some atypical (unfortunately also anonymous) examples bearing similar triangle stamps, we should allow some uncertainy.
My personal test is, if they look cheap and foreign, but say USA, they are probably Harrold.
LesserSon
PA USA
Purely speculative, addressing the “looks made in Germany or Japan” reactions: production methods and possibly demographics of the work force might have been common to Harrold, and in the rapid restoration of industry in post-war Axis nations, leading to a similar, primitive look to the tools.
Here is a recent addition to the Harrold world for me. Was poking around at an estate sale, could just barely make out the arrow head in the logo, and thought "Stiletto, cool". Got it into better light, realized it was the Harrold H we had talked about recently in another thread (Wood screwdrivers), so I will keep it here.
ETA: forgot I had a better pic of the logo
...it was the Harrold H we had talked about recently in another thread (Wood screwdrivers),
I was prompted...
Private Lugnutz made the connection between this screwdriver of mine and LesserSon's pliers with a similar logo.
...to talk about it here, too, going on a research tear upthread if you missed it...
Here's the original TM they apparently shortened later and a pretty good list of the tools they were making at that time.
But you didn't use the term "Arrow" for this thread, cuz lazy me searched for Harrold Arrow in the vintage forum, rather than do all the reading required to see your pic with the arrow. The downside of pasting images (😉, as you've convinced me to copy relevant image text to help the search engines), but you did in the wood screw driver thread.
...your pic with the arrow.
If you mean the trademark, "trademark" or "TM", for short, are the terms I usually use when describing TM's. I didn't call it an arrow in the other thread, either. While it's obviously also a double pointed arrow, it's the crossbars of the two letter H's in the original TM.
It's cool that you have a much more modern screwdriver with the same TM. Only the third or maybe fourth example on GJ.
LesserSon
PA USA
A recurring question on this and the Too Many Pliers thread:
IS THIS (rounded triangle)
the same manufacturer as THESE (sharp trianges)?
LesserSon
PA USA
The question has come up again in the context of slip-joint pliers, but long-nose pliers bear all these stamps, too. (well, not MY two pairs, but others do)
So if this is a Harrold,
then this is, too.
I think they are, but I don’t KNOW. I think we’re close.
We just need one example of these rounded-triangle stamp pliers to turn up with “Harrold” or an “H” on it, or to find a Harrold catalog with illustrations to KNOW.
Mintgrun
Kingston, Wa.
I'm no expert, but neither of the round-corner-triangle pliers look Harrold-made to me.
What about @Leviton 's pair marked Herbrand in the thread on this topic?
Herbrand make more sense to my feeble mind.
^ that looks like almost dead-on match other than the "Herbrand" script logo.
I'm fairly sure the reason that pair of @LesserSon's has that gold tone is because I used a brass brush to clean them up.
That "FORGED STEEL USA" inside the triangle with the rounded corners looks quite familiar - and the business end looks remarkably similar.
Mintgrun
Kingston, Wa.
The forgings look identical to my eye.
Scrolling back up the page, I see that @What_dont_you_want shared the same Herbrand pliers link in this thread.
Leviton shared them in post #45 too.
Now, I am wondering if the <-H-> inside the sharp triangles might refer to Herbrand, instead of Harrold. Although, there are pointy-triangle Harrold marked pliers too (post #14), so the fact that they both start with H is probably coincidental.
I don't see a single pair of Herbrand pliers in this thread (or elsewhere) that are "deep forged" like the pair in question. Meaning, the round-corner-triangle pliers have thick jaws and all the Harrold pliers are thin, stamped-out, bent jaws.
I don't see any other rounded-edge Harrold pliers like the round-corner-triangle needle-nose pairs either.
It's unfortunate that this discussion is spread out in three threads, but here we are....
^ Well.... this is not the first time we've discussed this one, @Mintgrun. This hasn't taken nearly as long to figure out as it took me to figure out the Kal/ProAmerica/Cam-Ron connection! :lol:
LesserSon
PA USA
I am partially persuaded away from thinking the mystery pliers are Harrold. I agree the forgings of the round-cornered stamp pliers are all the same. The Herbrand script pliers should date from the 1920s, if AA has it right, so at least some of the non-Herbrand marked round-cornered stamp pliers are contemporaneous. But the example of Herbrand script slipjoints on AA does not look exactly like Leviton’s example - AA’s is somewhat heavier, though it has the same number of course teeth.
I won’t be persuaded that <-H-> or even a plain H is other than Harrold. Herbrand has an H-in-a-diamond on some forgings, but I don’t think a plain H.
Not only do they both start with H, but they’re both located in Ohio. Inconveniently coincidental.
True.
Right! But where are the Herbrand script needle nose, either?
More legwork. I’m heading to the Herbrand thread to look for matching pliers.
:+1:
While the <-H-> marking is not exactly the <-H.J.H-> marking that Harrold TM'ed (a point I have made only in academic interest about the abbreviated version being a riff on the original version that is also consistent with the company name change), I think it would still be a very difficult challenge for Herbrand to defend using it without an infringement claim by Harrold.
Mintgrun
Kingston, Wa.
I searched "side cutters" in this thread and found Mr. Ed's and LesserSon's examples, but these are a bit different, in that they're not marked Harrold, aside from the H in the grips (the grip pattern is also different than the other two) and they're flush cutters.
I'm posting the needle nose pliers again, for the sake of comparing the two triangles side by side; there's one with an H and another with a space for one, but it's blank.
Both pair shair similar grips, with the 'needle-nose' having a slightly coarser weave.
I have two of the mystery needle-nose pliers now, with two different rivet styles, posted together for the fun of it.
(Both styles have been posted previously, but I enjoy seeing them side by side).
((Ooh, look. One triangle has two pointy corners and one rounded one)).
The forged ridge left on the handle grips is an interesting detail.
Eric Brown
I have a curiosity. During my German plier research I came across this Will, Made in Western Germany pair. This would have been Harry Will, between 1945 and 1990. On the other side it has Harrold. This begs the question: Is this the same Harrold and maybe they imported these pliers, or perhaps a different Harrold?
Mintgrun
Kingston, Wa.
Based on the style, I'd be surprised if there is any connection to the old Harrold tools. I've never seen Harrold pliers with the thick jaw tips like that. They all seem to be stamped out of thinner metal.
Is "Harry" short for Harrold? :) Just kidding. See next comment.
There are multiple examples, and multiple types (slip joint, lineman's, etc), of pliers marked both "WILL / MADE IN GERMANY" and "HARROLD" on eBait.
Agreed. But remember that...
...Harrold got conglomoed by Budd in 1977.
In that era, under those kinds of economic circumstances, anything could happen. According to Gerald over at 'Progress is fine, but...' blogspot, Harry P. Will Werkzeugfabrik was making pliers for Canadian Tire Corp, Benchcraft and others. Doesn't seem too much of a stretch to think they were also making them for the last vestiges of the Harrold brand in the hands of Budd's Woodings-Verona Toolworks subsidiary.
