Anyone burn Red Elm
rkevins
Central Arkansas
Does anyone use red elm for firewood, I have a tree that fell and hate to waste a good sized tree. It has been down about a year, my plan is to cut and split then mix with red and white oak.
Does it hold up to being stored in the dry, it will be a couple of years before I would need it or would it need burned sooner?
gmcgeo
Red Elm is good for like Spring / fall. it does not burn as hot as Oak, it also has a distinct smell to it.
It does smoke a little more then oak and ash. Id use it if its well seasoned
cdoublejj
MO
as hard as hardwood is to come by why do burn it instead of making table legs?
PopcornSutton
Northern Tip of VA
I'm with those who burns anything that isn't a pine type. I have cut many "tree of wonder" on my property. It's crappy wood, soft and no strength, but when dry it burns. Heat output my be low, but it's free.
alfadan
Augusta, ks
I like it. Burns decent when seasoned a couple years. Splits well and the bark is usually falling off already after a couple months in the round. Standing, barkless dead are great!
cdoublejj
MO
yall seen those rocket stoves that will be burn a cardboard box's worth of wood for week?
Firebrick43
West central Indiana
I have burned red/slippery elm in my stove and it worked well if it was well dried for 2 years.
I wouldn’t burn it in a fire place due to the smell of piss
It does smell less if well dried.
A closely related species is Siberian elm which has the nick name of piss elm. I can’t tell if one smells worse than the other.
gmcgeo
I do not understand your question. A cardboard Box's full of wood???? How big is this box? what type of wood?
Most realistic backyard setups with a standard rocket stove (no large thermal mass), using just one box + wood is unlikely to get you continuous heat for a full week. It might get you through some days, or through the cold hours each night, but expect some drop-off.
mike93lx
Richmond, VA
