anyone done this....
diovol
ontario, canada
just wondering if anyone has ever mounted a compressor to just some 4"x4" pieces of wood and not legged them to the concrete floor and have been trouble free with vibration?
muibubbles
nj
lol mines sitting on a 2in piece of Styrofoam on top of cardboard and no vibrations...
oldgoaly
Shiloh, Il
Some 1/4" thick medium soft rubber under the corners of wood makes a world of difference, then a a small room to almost make it quiet so you can talk normal near it.
Vettman
Ca. Sierras
I mounted my compressor on 3 hockey pucks (hard rubber). Doesn't move at all, very stable.
nehog
Jaffrey, NH
Mine, a horizontal, just 'sits' on the floor, bolted to a couple of short 2x4s. Was once on some carpet for noise reduction, but it kept walking away while running. I might, some day, stick some rubber under it, but I'm not in a hurry since it doesn't cause any problems, and I don't want it any higher than it is now (it is under a workbench where there is limited space above it.)
rickairmedic
louisville ,Ky
I cut down the pallet mine came on and its been on it since I got it home no problems and only time it has moved was when I moved it .
Rick
LIVELY
Illinois
my craftsman is still on the shipping crate[cut down to the leg widths] that it came on 40 years ago:)
JC23
Northcoast
Sounds like I did what a few others have done. I cut down the pallet it came on to be the same footprint as the compressor (an upright). That way, it doesn't take up any more room that it needs to. Made sure the contols and oil drain are pointed into the garage as opposed to the wall. No problems for over 10 years, now.
The few times I've had to move it, like to change out the regulator/dryer that's on the wall behind it, I just 'walked' the pallet away from the walls. I'll do it again if'n I need to.
BTW, keeping it on a pallet spaces it from the wall the correct amount for clearance, access and air flow.
Rixter58
Nowthen, Mn
Plenty of people leave their compressor on the pallet its delivered on
Or even a step further. Mine is on the pallet....which is on a set of snowmobile dollies. No, this is not permanent, but the compressor is situated in the ver last portion of the shop to be sheated and painted. Should be coming off the dollies in the next week or so.
EuroVt
Central Vermont
My Eaton is on the concrete with no bolts. I intended to bolt it down, it's been a year and it hasn't gone anywhere, so I probably will do nothing.
54FordPanel
Fort 54, Littleton, Co
I have 3 layers of rubber and 2 layers of wood on mine, and it's not screwed down to the floor, so it's movable.
MrJoshua
NY
Like others mine is sitting on the pallet it came on. No problems at all and keeps it up out of the moisture from the concrete.
Ae86 sr5
My champion is on the floor nother under it no problems it only has a 1-2 hp motor tho
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Old mudflaps would work great as Joe69 says. Or cut 4 squares out of an old tire. A long as you have something under it instead of metal to concrete, the compressor will not move. Even 4 pieces of indoor/outdoor carpet will work just fine
Ohio Auto
My pallet is still sitting on the same pallet it came with. Never have had a problem.
Chris Adams
Big plastic spacers for my 15 amp compressor. I had the same spacers on my 15 amp that I sold, minus the spacers.
The 25 amp was still on the pallet it had shipped on when I got it used.
koditten
Midland, Michigan
Thats how mine is mounted. used 3, 6'' 4 x 4's. This raised mine up enough that I could put a real ball valve on the bootom. Got rid of that stupid pet **** thing. This also raised the a/c up high enoug that I can roll my floor jack under the compressor. Now they both take up the same floor space.
