Anyone else like Channellocks?
GX460DIYguy
Texas
Found these today. They had the rubber grip on them and it was in pretty bad shape so I cut it off to find a bunch of rust. It’s not vintage made in the USA goodness, but they cleaned up pretty good. Who makes them in Spain for them? I’ll have to add them to the box tomorrow.
neophyte
Pennsylvannia
The Channellock Soanish adjustable wrenches are made by Irega.
It may be possible to buy replacement Irega branded grips.
neophyte
Pennsylvannia
I actually prefer them without the grips. Easier to keep them from rusting under the grip. We don’t use them for anything real heavy duty anyway.
I can understand that.
Years ago, when I first looked into Irega, my understanding from the catalog I received, was that the grips were designed to be removable, and replaceable, and that the underneath wrench was just made the same as a non “gripped” wrench.
Other manufacturers like Crescent, would skip stamping logos etc. into the steel wrench handles, when making rubber dipped wrenches, because the information and branding was printed onto the rubber grip.
Nowadays, Irega also makes wrenches with dipped handles, but it looks like they still forge their information into the handle on those as well.
I've typically found the mfg. marking under grips, so I don't know if you mean a specific MFG or not; the translucent green grips you can sort of see the markings in the right light.
impactims
I find Chanellock to be OK at best, generally speaking.
I have never had them perform well under demanding conditions. Yes, they are USA made, which is nice. But that's really the only thing they have going for them.
engineer2
Chicago burbs
I have a mini pair of Channellocks and use them frequently. Wish they were plated as they could very easily rust.
I have a large pair that are broken (roadside find). They will replace then for free, but the shipping cost is quite high.
How Mini? if small enough. more people then me are playing with nickle plating.
I need to move all my Channellocks to a drawer in the 42” box. 1.5 drawers in a 27 is stupid.
How are you storing them; and are most the arc joints? I have way too many of the latter and started storing then side by side "vertically" as if they were racked, but no spaces.
engineer2
Chicago burbs
I'm thinking about getting into some home plating. I even bought a power supply to do small parts. I accidentally dropped one lead onto the other and the "short circuit protected" power supply let the smoke out. No service, no diagram, no parts available from China.
PS for plating - USB powered:
Portable Plating setup - USB PS/VR - under $20 when I got mine.
https://www.amazon.com/PEMENOL-Adju...-Voltmeter/dp/B07RXZ52KR?tag=atomicindus08-20
Airstone pump - to agitate the plating solution for Larger projects
https://www.amazon.com/ALON-Oxygen-Aquarium-Hanging-Buckle/dp/B098Q98395/?tag=atomicindus08-20
Nickel welding rods for the anodes - hammer on the flux crud and it comes off:
Other:
Mason jars for the Nickle acetate
Making the Nickle Acetate: -Wear personal protection and do this outside as you don't want to be breathing the fumes.
cut a nickle welding rod in half and put then in ordinary white vinegar (EDIT: + 1/2 Tsp of salt to make it more conductive), connect to the USB power supply (don't short them out... - put a 2A fuse in line... EDIT: I also made a set of clips to the top edge of the jar and a plastic "spacer" for the lower ends) and run for a day or two until its a nice dark green - you are ready to plate
Polish the heck our of your part and plate. Brass/Copper is easy,
I used an old UPS 12V battery, with a lighter socket connected, and a lighter socket USB to plug the USB PS into
Numerator2142
Do y'all expect new channel locks to be a little "stickey" and require a break-in? I got a pair of 426's (the 6" guys) today and the max open is kind of fiddley and gets stuck. Trying to decide if I should take them back and exchange them.
Ton ton
Page County,VA
I found an old style 430 tongue and groove pliers on the side of the road - channellock brand. It has a nut you can tighten. What year did channel lock switch to the current style?
AreBeeBee
Wisconsin
Alloy Artifacts shows a model 440 with a rivet instead of a nut in its Channellock entry at The Blue Handle Era: "Although not marked with a patent number, these pliers are held together by a rivet as described in patent #4,603,607."
The patent was applied for in 1982 and granted in 1986; it's available here. The patent covers using rivets as pivots for slip-joint pliers, saying, "This invention is intended to provide a pivot connection for slip joint pliers which is stronger than the nut and bolt connection now in use."
AreBeeBee
Wisconsin
4C -- I have several Channellocks hung on a pegboard, and where I have more than one of a given size, the nut-and-bolt version goes up in front of the riveted. For just the reason you mention.
One of my riveted ones worked loose, so I put it on the railroad rail that's my anvil, and gave the rivet a smallish bang with a hammer. I was pretty careful because I knew it would be a PITA to loosen it a skosh if I slugged it too hard. Luckily I didn't, but it would be all too easy to do.
It's the nut version by universal (?) preference.
Ton ton
Page County,VA
Thank you!
NoahG
Detroit, MI
On the subject of rivets, a coworker had the rivet on a pair of 909 crimpers shift last week making them impossibly hard to open. The pair is less than two years old and gets light use.
My 15 year old pair is still nice and smooth.
lilscorpion
Colorado
Honestly - I was planning on buying/having a full set but when I received a set of needle nose pliers that were obviously ground by hand, and sloppily so, I decided that I’ll go all in on Knipex after returning them only to get another set exactly the same.
Red handles are better than baby blue too…IMO OC course
KnurledNut
n/a
Picked this up on vacation the other day. 14" drive spinner handle with a female end in the handle.
What I noticed on the backside of the tag. ...exclusively for Do It Best Corp.
I have the same one and bought it from Do It Best.
jeffmoss26
Cleveland, Ohio
They do! The CL name is licensed for all these other products which are only sold through the Do it Best hardware co-op.
