Anyone else still use socket caps?
Tools4Me
I have a bunch, but I mainly use the Apex version. I prefer them because you can choose between several different size options for the hex end (small for really tight areas and lower torque requirements and larger for more torque capability). The hex end also has a ball detent on it, so when it's placed in a wrench box end you don't have to constantly hold it in place to keep it from slipping right out (like the Craftsman version and most other similar options).
I also have the chrome quick release ones Mr_B posted above (post #31). They work great for areas where there's just a little bit more headroom, because they completely prevent the socket from falling off during use. They don't get used often but they work great for adding a socket to the end of an offset or deep offset wrench for access into strange areas where a ratchet, pass through socket, or regular wrench won't reach. I also use them occasionally to add a socket to my zero degree hi-performance wrenches so they can reach deeper into recesses without the wrench handle itself sitting at a more standard 15 degree angle.
The Apex adapters are quite expensive new, but they can be found used on Ebay for good prices if you're patient. That's how I obtained the 10-15 I have in all 3 drive sizes.
Some models of the Apex adapters are pin lock, some are ball detent, and many of the newer ones are the style that works for both (the leading edges of the pin lock pin are beveled), so make sure you are getting the style you want if you are buying new or used.
mepstein
"Limited-access" tool, like the kinda-boomerang shape of an automotive electrical starter wrench or an exhaust manifold wrench. The Harbor Freight set is a good compromise. I have a set, waiting.
When cars still had distributors, that L-shaped wrench to loosen the distributor bolt was another "limited-access" tool. Sometime in the not too-distant future, asking a younger person about the purpose of one of those will elicit an 'I dunno' shrug.
We call them an SSI wrench because they reach under the exhaust on Porsche cylinder heads so you can tighten the nuts on the exhaust studs above the heat exchangers.
seber
Deep East Tx.
I'm still lost. How is that better than a 3/8 tall ratchet? The caps on those look at least that tall.
mailpup
Los Angeles
I have a K-D branded set of these that I bought many years ago. They came in a plastic pouch and I'm pretty sure they are the same as (Sears) Craftsman. I use them occasionally but when needed they can save my ****.
toyotadriver
I have one of those L shaped distributor wrenches. I've used it too. But, no vehicle I currently own has a distributor and I haven't used the tool in many years. Probably last used in the 1990s. Maybe one day I'll need it for something.
I also have a timing light...and haven't used that in many years either.
Kenstone1
This thin 1/4 and 3/8 drive dual head ratchet will get you the same stack height as a socket/socket cap/ratchet wrench.
Read the reviews...
I have one and use it a lot for tight spaces but it "self-switches direction" a lot.
jmo,
Boogerman
aspen cove hill
One way solve problem; look good. More one way do things, more way better chance solve problem. Don't have, would like.
My tools, solve bit ratchet, 1/4 wrench/bit, or pass socket:
G
Gurp
So.Ohio
I prob should have included a picture on the tool not in use as well for those unfamiliar.
You dont need them often but when you do then are a life saver.
Old school automotive stuff. much like the moon wrenches and distributor wrenches mentioned above.
I always keep a set of these, crowsfeet and in my personal box. added with stubby ratcheting and flex head ratcheting wrenches you can get in places you thought you would never. Not saying that is always a good thing either haha.
chipdog4
Southern Indiana
Had to dig my set out for a rear diff fluid change on my AWD Ford Edge.
Couldn't get a ratchet in there nor an extension. A wobble extension may have fit.
captain14
Forgot I even had these!
I’ve never used them. Bought them at local Sears 5-7 years ago before it closed. Figured one day might by handy. 🤷‍♂️412B6CF1-7B2D-404A-B455-32E2735A8F67.jpeg
I bought a set of these when the last Sears in the area was doing a massive warehouse clearance event six months before they closed.
I also have the two sets of Ceaftsman wrench sockets. I’m sure I picked them up during one their 1/2 price sales years ago.
One time use and they pay for themselves .
