Anyone know what these are?
Echodawg
Bay Area, CA
I just started working on the garage back wall in anticipation of getting it sorted. There are two "electrical boxes" above my circuit panels that I have no idea what they could be. Anyone have any ideas? Especially the one on the right, almost looks like some sort of buzzer on it. The last photo is of the box on the left with the cover plate removed. Any help would be appreciated.
tornadocaster
Edmonton, AB. Canada
HelloEchodawg
That's a transformer. It could either be for a door bell or furnace thermostat. It's easy to get a reading off the terminals for voltage and then try shutting off the breaker to the furnace.
Give it a shot. I could be wrong but a few houses I've owned, had these.
Good luck
Giovanni
AndrewDouglasBird
Vancouver, WA
Related question - Why do they always put an externally mounted transformer for the door bell in the garage? Why aren't these built into the door bell?
Bib Overalls
Jonesboro, Arkansas
Code requires any splice or tap in a line to be made inside a box that is accessible. The box on the left is a simple splice and the box on the right is a simple tap for the door bell transformer. I try to do this in the attic if I have access but sometimes there is no option and you have to do it in a wall.
dogdog
if it is 16V on the output it's a door bell... think all door bell transformers are 16V AC.
