Aprilair 700A -problem solved thanks
fitter30
Peace Valley,mo
Aprilair 700a is a humidifier. Unit is tripping one of its safeties and locking out. Could be low on refrigerant or dirty have u checked its filter.
Rogue1987
Missouri
The 700a is a humidifier, not a dehumidifier. If its running it is adding humidity to the air, not taking humidity out of the air. The humidistat should not be allowing it to run (I would hope with 66% RH when you're trying to cool the building.). You would probably want to look at the rest of the HVAC system to determine why its not removing humidity, I would assume something somewhere is not functioning properly.
ETA: Not that its much help with the current issue of too much humidity, but if the building was built in '08 the humidifier would probably benefit from a new water panel next heating season.
Maxcustody
West Virginia
Thank you, I am wrong in my thinking of the system. I was under the impression it was a dehumidifier. I need to read more about this system obviously. It may be running as intended.
Rogue1987
Missouri
If you post some information about the existing HVAC system some of us may be able to point you in the direction you need to go.
Is the house cooling, and just high on humidity? I'd check the condensate drain out of the inside air handling unit first, and make sure that the moisture that's condensing has somewhere to go!
Maxcustody
West Virginia
Thank you. I did replace the water panel this past winter due to it being clogged up.
We have a geo thermal system, I do not know much about it. I have had it serviced several times since we bought the house in 2019. Last repair was a compressor replacement.
"Is the house cooling, and just high on humidity?"
I think everything seems to be working fine. I think looking at the % on the humidifier I was thinking it should be on (dehumidifier), however as you said it is not a dehumidifier as I thought..........................if that makes any sense.
