Ohio Andy
My goto non-skip don't care that much what happens to it socket set has been the SK Mechanics Tool Set, 1/4" & 3/8" & 1/2" Drive Socket with 216-P Ratchet, 149-Piece, SAE & Metric, SuperKrome Finish, with Storage Suitcase for $200.
If I need to carry something somewhere I grab it and off I go. This is a non-skip set with decent range both standard and deep SAE and Metric.
I decided to give a GearWrench set a try because it is less expensive (about $150) and has a few sockets that the SK does not. Cheap enough that I do not worry that much about what happens to it. These are sets that I might use as a loaner set or just something that I drag off somewhere questionable, as opposed to my more expensive socket sets.
www.gearwrench.com
The set includes a 1/4 Female to 3/8 Male adapter and I decided to do my first test of the 1/4 ratchet with that to make sure I can pop things on and off that ratchet. It was so tight I went back to see what is included in the set so that I could verify that it was indeed a 1/4 female. After verifying that it SHOULD be able to fit on that ratchet I just forced it on. It was equally difficult to get it off. With practice I can get it on, but I can honestly say that I have never seen any ratchet this difficult to get things on and off.
I grabbed a mini Titan 1/4 ratchet and all the sockets went on and off no problem. I grabbed a 1/4 Flex Head Proto I had nearby and that was the similar. OK, so in a pinch I can use the GearWrench 1/4 ratchet, bit so totally not worth the hassle. This entire set is going back.
The 3/8 and 1/2 are a tight but usable. I own over 50 ratchets and I have never seen this before. Anyone have good luck with GearWrench Ratchets?
GEARWRENCH 185 Piece Mechanics Hand Tool Set - 1/4", 3/8”, & 1/2" Drive | 90 Tooth | SAE & Metric | GW90MCBMTS - Amazon.com
www.amazon.com
GW90MCBMTS 185 Piece 1/4", 3/8” & 1/2" Drive 90T SAE/Metric Mechanics Hand Tool Set - Gearwrench
Count on GEARWRENCH to get the job done. Get the GW90MCBMTS 185 Piece 1/4", 3/8” & 1/2" Drive 90T SAE/Metric Mechanics Hand Tool Set here.
